[gdal-dev] core dump on dir info
Michael Sumner mdsumner at gmail.com
Fri Feb 2 22:15:08 PST 2024
Thanks Even, so there's something about tiledb under gdb (or maybe I am
mangling the context,  I will try variants of the host I'm using). Run with
valgrind included below.
gdb --args ogrinfo /tmp/newdir/
(gdb) run
Starting program: /usr/local/bin/ogrinfo /tmp/newdir/
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffe7757640 (LWP 988)]
[New Thread 0x7fffe6f56640 (LWP 989)]
[New Thread 0x7fffde755640 (LWP 990)]
[New Thread 0x7fffd5f54640 (LWP 991)]
[New Thread 0x7fffc5753640 (LWP 992)]
[New Thread 0x7fffc4f52640 (LWP 993)]
[New Thread 0x7fffb4751640 (LWP 994)]
[New Thread 0x7fffabf50640 (LWP 995)]
[New Thread 0x7fffab74f640 (LWP 996)]
[New Thread 0x7fffa2f4e640 (LWP 997)]
[New Thread 0x7fff9a74d640 (LWP 998)]
[New Thread 0x7fff91f4c640 (LWP 999)]
[New Thread 0x7fff8974b640 (LWP 1000)]
[New Thread 0x7fff78f4a640 (LWP 1001)]
[New Thread 0x7fff78749640 (LWP 1002)]
[New Thread 0x7fff6f5ff640 (LWP 1003)]
Thread 1 "ogrinfo" received signal SIGILL, Illegal instruction.
0x00007ffff3773c9e in tiledb::common::ThreadPool::ThreadPool(unsigned long)
() from /lib/x86_64-linux-gnu/libtiledb.so.2.16
valgrind -s ogrinfo /tmp/newdir
==704== Memcheck, a memory error detector
==704== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==704== Using Valgrind-3.18.1 and LibVEX; rerun with -h for copyright info
==704== Command: ogrinfo /tmp/newdir
==704==
INFO: Open of `/tmp/newdir'
      using driver `ESRI Shapefile' successful.
1: geo_melbourne (Polygon)
==704==
==704== HEAP SUMMARY:
==704==     in use at exit: 25,486 bytes in 216 blocks
==704==   total heap usage: 15,761 allocs, 15,545 frees, 2,390,169 bytes
allocated
==704==
==704== LEAK SUMMARY:
==704==    definitely lost: 0 bytes in 0 blocks
==704==    indirectly lost: 0 bytes in 0 blocks
==704==      possibly lost: 544 bytes in 1 blocks
==704==    still reachable: 24,942 bytes in 215 blocks
==704==         suppressed: 0 bytes in 0 blocks
==704== Rerun with --leak-check=full to see details of leaked memory
==704==
==704== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
ogrinfo /tmp/newdir
Illegal instruction (core dumped)
Cheers, Mike
On Sat, Feb 3, 2024 at 12:46 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> I'm wondering if there not might be something wrong with your build or
> runtime environment. Or there's something subtle, because that works fine
> for me with my dev build or in the ghcr.io/osgeo/gdal:alpine-normal-3.8.3
> Docker image
> Try running "valgrind ogrinfo /tmp/newdir/" or "gdb --args ogrinfo
> /tmp/newdir/" (type "run") to get more useful information
> Even
> Le 03/02/2024 à 02:35, Michael Sumner via gdal-dev a écrit :
> I'm getting Illegal instruction / core dumped on ogrinfo of a directory:
> ogr2ogr /tmp/newdir
> https://github.com/SymbolixAU/geojsonsf/raw/master/inst/examples/geo_melbourne.geojson
> -f "ESRI Shapefile"
> I've worked back through some docker images and it wasn't a problem in
> 3.6.0, but I'm getting it since 3.7.0 - or I'm doing something wrong
> entirely.
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240203/8027dea6/attachment.htm>
