[gdal-dev] ECW plugin
Even Rouault even.rouault at spatialys.com
Sun Feb 4 14:58:41 PST 2024
you need to download the ECW SDK from
https://supportsi.hexagon.com/s/article/ERDAS-ECW-JP2-SDK-v5-5-Update-4-Release-Announcement?language=en_US
and install it
and then point to it with the CMake variables indicated at
https://gdal.org/development/building_from_source.html#ecw
Cf
https://github.com/jef-n/OSGeo4W/blob/6a17ff489bd6dcd583cbfa51b542966ba2961c7d/src/gdal/osgeo4w/package.sh#L150
for the build recipee of the OSGeo4W GDAL build with ECW support
Even
Le 04/02/2024 à 22:54, Marián Hadri via gdal-dev a écrit :
> Hi,
> I've build GDAL version 3.8.3 in VS2019 from source files
> "gdal-3.8.3.tar.gz". For creating project file "GDAL.vcxproj"
> I used CMake program. I've added variables PROJ_INCLUDE_DIR =
> C:\OSGeo4W\include and PROJ_LIBRARY = C:\OSGeo4W\lib\proj.lib
> and everything worked fine. When I added gdal.dll to our project ...
> it worked fine, it convert raster files and so on. But I have one
> problem,
> I need to add ECW plugin to GDAL 3.8.3 project. Could you help me, how
> to do it ... ?
> Thanks in advance, Marian Hadri
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240204/f561802b/attachment.htm>
