[gdal-dev] core dump on dir info
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Feb 6 05:46:24 PST 2024
Could you set up your VMs to include those SSE instructions? I think that
keeping VMs that "old" configured is a source of problems using
pre-compiled binaries.
The same way GDAL updates dependencies of compilers and other libraries to
something more modern (but not too modern), those SSE instructions should
be updated.
@Even knowing now that the "old" hardware is "virtually old", should we
remove AVX2 compatibility from ubuntu-full-latest? I do not know how much
is the performance impact.
Cheers,
Javier.
On Mon, 5 Feb 2024 at 21:54, Michael Sumner <mdsumner at gmail.com> wrote:
> yes, jammy VM on openstack is the host (and is where I run pretty much
> everything, though will increasingly use AWS).
> Thanks for the note, I'll try on other systems too. We need a
> security-allow set for vsicurl to work so if there are other little details
> I'll be keen to flush them out.
> Cheers, Mike
> On Mon, 5 Feb 2024, 18:44 Javier Jimenez Shaw, <j1 at jimenezshaw.com> wrote:
>> Hi Mike
>> Out of curiosity, are run running it in a virtual machine?
>> A few year ago I had problems running a program in a virtual machine
>> (virtualbox, but I read it happens in others) due to a missing SSE
>> instruction. The solution there was to "enable" the missing instructions in
>> the virtual machine configuration (that I don't know why it was not the
>> default).
>> Cheers
>> On Mon, 5 Feb 2024, 02:04 Even Rouault via gdal-dev, <
>> gdal-dev at lists.osgeo.org> wrote:
>>> ghcr.io/osgeo/gdal:ubuntu-full-latest has been regenerated with the
>>> rebuild of TileDB without AVX2. I've also enabled the
>>> drivers-with-external-depencies-built-as-plugin GDAL build mode, so it is
>>> easy to just remove a given plugin by deleting the corresponding .so in
>>> /usr/lib/x86_64-linux-gnu/gdalplugins
>>> Even
>>> Le 04/02/2024 à 22:51, Michael Sumner a écrit :
>>> indeed there's no avx2:
>>> cat /proc/cpuinfo|grep sse|head -n 1
>>> flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge
>>> mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt
>>> pdpe1gb rdtscp lm rep_good nopl cpuid extd_apicid tsc_known_freq pni
>>> pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes
>>> xsave avx f16c hypervisor lahf_lm cmp_legacy svm cr8_legacy abm sse4a
>>> misalignsse 3dnowprefetch osvw xop fma4 tbm perfctr_core ssbd ibpb vmmcall
>>> tsc_adjust bmi1 virt_ssbd arat npt nrip_save arch_capabilities
>>> Cheers, Mike
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240206/916ea3fc/attachment.htm>
