[gdal-dev] WriteBlock() not supported using JP2ECW driver?
Even Rouault even.rouault at spatialys.com
Wed Feb 7 12:16:44 PST 2024
For future doc readers: https://github.com/OSGeo/gdal/pull/9211
Le 07/02/2024 à 20:45, Even Rouault via gdal-dev a écrit :
> Scott,
>> I’m trying to create a JPEG2000 file using the JP2ECW driver, but I’m
>> getting “WriteBlock() not supported…”.  The same code works using the
>> PNM driver.
>> What am I missing?
> This comment in the code
> https://github.com/OSGeo/gdal/blob/0255b1d767bbfc6910d8044e37019f1d1ea5a617/frmts/ecw/ecwcreatecopy.cpp#L1653
> which basically says that there's some form of Create() support in the
> JP2ECW driver but you need to write by scanline from top to bottom.
> The PNM, GTiff etc drivers implement full random-writing, which is
> what is required typically for gdalwarp. The workaround is either to
> modify the way you write the file (if you use the API), or if you use
> GDAL tools to write to an intermediate format (GeoTIFF) and then
> gdal_translate to JPEG2000 afterwards.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240207/314cf49e/attachment.htm>
