[gdal-dev] [EXTERNAL] Re: Jp2 driver "unhandled projection"
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Fri Feb 9 09:37:52 PST 2024
Hi Even,
I can share in private the image.  Should I send it directly to your @spatialys.com account?
Jesse
Date: Friday, February 9, 2024 at 12:24 PM
To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>, "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] Jp2 driver "unhandled projection"
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Le 09/02/2024 à 18:13, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev a écrit :
I noticed a warning after converting a gtiff image to jp2 stating ‘Warning 6: Unhandled projection method Albers_Conic_Equal_Area’.  The driver apparently completes the conversion and happily reports the projection correctly under gdalinfo.  But I find it weird that the format would care about the projection.  Is this a serious warning?
It is a bit strange that you get this warning (especially since this should be a projection method handled by GDAL) and get a SRS after the projection.
It is fully expected that the JP2OpenJPEG driver tries to get georeferencing from the metadata. There are several ways to embed georeferencing in a JPEG2000 image : GeoJP2, GMLJP2. All JPEG2000-capable drivers in GDAL share the same code to read that georeferencing when present and expose it.
Any link to that JP2 image? (sometimes images have both GeoJP2 and GMLJP2, or possibly a side-car file. I'm wondering if the warning might not come from an attempt at reading with one method, and finally a fallback is used)
Even
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240209/6552e6ef/attachment-0001.htm>
