[gdal-dev] Build static GDAL-Lib and static GDAL-Apps
Roger Bivand Roger.Bivand at nhh.no
Tue Feb 13 04:21:08 PST 2024
You may find the listings used to build static libraries for R Windows packages using MXE as the basis to be helpful:
https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/toolchain_libs/mxe/src/
These are targeted at Windows, but the dependency tree logic should be similar. In building the successive static libraries, very likely the link order will matter too, so some patience is needed.
Hope this helps,
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
