[gdal-dev] CPLCalloc() used for small memory allocations. And for big ones?
Laurențiu Nicola lnicola at dend.ro
Wed Feb 14 01:00:59 PST 2024
On Wed, Feb 14, 2024, at 10:53, Abel Pau via gdal-dev wrote:
> Hi,
> I am currently working on a driver and have been utilizing CPL_calloc(). However, when attempting to pass the Actions, I encounter errors such as:
> warning C4244: 'function': conversion from 'MM_INTERNAL_FID' to 'size_t', possible loss of data
> This issue can be addressed by casting 'MM_INTERNAL_FID' (which is a GUInt64, essentially an unsigned long long) to 'size_t' (also essentially an unsigned long long). So, utilizing a cast is not problematic in this context.
The warning makes sense on 32-bit platforms, where that cast will be problematic.
However, while I didn't check what MM_INTERNAL_FID is, it doesn't sound like something calloc() would take.
> However, I noticed in the function description it states "used for small memory allocations," which prompts me to inquire if there is an alternative calloc function for larger memory allocations
"Small" probably means "infallible" here. If you want a fallible allocation (which you're supposed to handle), you can use VSICalloc(), VSIMalloc() etc.
Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/7936fe7d/attachment.htm>
