[gdal-dev] CPLCalloc() used for small memory allocations. And for big ones?
Abel Pau a.pau at creaf.uab.cat
Wed Feb 14 00:53:34 PST 2024
I am currently working on a driver and have been utilizing CPL_calloc(). However, when attempting to pass the Actions, I encounter errors such as:
warning C4244: 'function': conversion from 'MM_INTERNAL_FID' to 'size_t', possible loss of data
This issue can be addressed by casting 'MM_INTERNAL_FID' (which is a GUInt64, essentially an unsigned long long) to 'size_t' (also essentially an unsigned long long). So, utilizing a cast is not problematic in this context.
However, I noticed in the function description it states "used for small memory allocations," which prompts me to inquire if there is an alternative calloc function for larger memory allocations. If not, I will proceed with casting the variable in all instances. Nonetheless, I would appreciate knowing if there is a cleaner solution available.
Thank you for your assistance.
/*                             CPLCalloc()                              */
* Safe version of calloc().
* This function is like the C library calloc(), but raises a CE_Fatal
* error with CPLError() if it fails to allocate the desired memory.  It
* should be used for small memory allocations that are unlikely to fail
* and for which the application is unwilling to test for out of memory
* conditions.  It uses VSICalloc() to get the memory, so any hooking of
* VSICalloc() will apply to CPLCalloc() as well.  CPLFree() or VSIFree()
* can be used free memory allocated by CPLCalloc().
* @param nCount number of objects to allocate.
* @param nSize size (in bytes) of object to allocate.
* @return pointer to newly allocated memory, only NULL if nSize * nCount is
* NULL.
Abel Pau Garcia
GIS developer
[https://www.creaf.cat/sites/default/files/creaf-signature.png]
a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>
Let's chat on Teams!<https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/so-en-signature.png]
[https://www.creaf.cat/sites/default/files/twitter-icon-signature.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png]<https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>[https://www.creaf.cat/sites/default/files/youtube-icon-signature.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram-icon-signature.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat<http://www.creaf.cat> | http://blog.creaf.cat
[https://www.creaf.cat/sites/default/files/uab_logo_signatura.png]
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
Before printing this electronic message, think about the environment.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0006.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0007.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0009.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0010.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0011.png>
Type: image/jpeg
Desc: image007.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0002.jpg>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240214/a893a4e9/attachment-0003.jpg>
