[gdal-dev] Build question: GDAL with libwebp....
Carl Godkin cgodkin at gmail.com
Thu Feb 15 05:49:20 PST 2024
On Wed, Feb 14, 2024 at 9:06 PM Kai Pastor, DG0YT <dg0yt at darc.de> wrote:
> Did you try to quote for the linux command line, instead of escaping:
> "-DWEBP_LIBRARY=/usr/local/devlibs/libwebp-1.3.2/lib64/libwebp.a;/usr/local/devlibs/libwebp-1.3.2/lib64/libsharpyuv.a"
> (YMMV. "LIBRARY" usually isn't for lists at all.)
Hi Kai,
Yes, it behaves the same way.   I had tried that too earlier and just
double-checked it.
I'll live with my workaround.  Another possibility is to use an older
version of libwebp, from before version 1.3.0 when the "libsharpyuv" code
was added.
Thanks a lot,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240215/aa6a2eee/attachment.htm>
