[gdal-dev] GDAL does not support gpkg files generated by GeoServer
Raymond Nijssen r.nijssen at terglobo.nl
Wed Feb 14 05:51:08 PST 2024
Some fields in geopackages generated by GeoServer are not supported by
GDAL. I have already made a ticket for GeoServer, but I'm unsure where
the problem lies.
More info in the GeoServer ticket here:
https://osgeo-org.atlassian.net/browse/GEOS-11292
Gpkg output can contain fields of type INT4, VARCHAR(255) and FLOAT8
which are not supported by GDAL/OGR. For this reason, QGIS, GRASS and
FME ignore those fields on import.
ray at fw13:~/Downloads$ ogrinfo ext_nat_nbp.gpkg
Warning 1: GPKG: unrecognized user_version=0x00000000 (0) on
'ext_nat_nbp.gpkg'
INFO: Open of ext_nat_nbp.gpkg'       using driver GPKG' successful.
Warning 1: Field format 'INT4' not supported. Interpreted as INT
Warning 1: Field format 'VARCHAR(255)' not supported
Warning 1: geometry column 'deelgebied' of type 'VARCHAR(255)' ignored
Warning 1: Field format 'FLOAT8' not supported
Warning 1: geometry column 'oppervlakte_hectare' of type 'FLOAT8' ignored
Warning 1: geometry column 'plan_naam' of type 'VARCHAR(255)' ignored
1: ext_nat_nbp (Multi Polygon)
The INT4 fields are visible as INT, but all other other fields are
ignored. (There’s also an “unrecognized user version“.)
This also affects QGIS, GRASS and FME, cause they use GDAL for opening
the data source.
Who's right and who's wrong here? :)
Kind regards,
Raymond
