[gdal-dev] GDAL does not support gpkg files generated by GeoServer
Even Rouault even.rouault at spatialys.com
Sun Feb 18 09:57:51 PST 2024
http://www.geopackage.org/spec/#_sqlite_container "Table 1. GeoPackage
Data Types" is pretty clear on which data types are valid in a
GeoPackage vector table, and INT4, VARCHAR(...) or FLOAT8 are not.
You can also use the
https://github.com/OSGeo/gdal/blob/master/swig/python/gdal-utils/osgeo_utils/samples/validate_gpkg.py
script although it is not official, but hopefully should be faithful to
the spec. Otherwise you can use the official validator at
https://cite.opengeospatial.org/teamengine/
Even
Le 14/02/2024 à 14:51, Raymond Nijssen via gdal-dev a écrit :
> Some fields in geopackages generated by GeoServer are not supported by
> GDAL. I have already made a ticket for GeoServer, but I'm unsure where
> the problem lies.
> More info in the GeoServer ticket here:
> https://osgeo-org.atlassian.net/browse/GEOS-11292
> Gpkg output can contain fields of type INT4, VARCHAR(255) and FLOAT8
> which are not supported by GDAL/OGR. For this reason, QGIS, GRASS and
> FME ignore those fields on import.
> ray at fw13:~/Downloads$ ogrinfo ext_nat_nbp.gpkg
> Warning 1: GPKG: unrecognized user_version=0x00000000 (0) on
> 'ext_nat_nbp.gpkg'
> INFO: Open of ext_nat_nbp.gpkg'       using driver GPKG' successful.
> Warning 1: Field format 'INT4' not supported. Interpreted as INT
> Warning 1: Field format 'VARCHAR(255)' not supported
> Warning 1: geometry column 'deelgebied' of type 'VARCHAR(255)' ignored
> Warning 1: Field format 'FLOAT8' not supported
> Warning 1: geometry column 'oppervlakte_hectare' of type 'FLOAT8' ignored
> Warning 1: geometry column 'plan_naam' of type 'VARCHAR(255)' ignored
> 1: ext_nat_nbp (Multi Polygon)
> The INT4 fields are visible as INT, but all other other fields are
> ignored. (There’s also an “unrecognized user version“.)
> This also affects QGIS, GRASS and FME, cause they use GDAL for opening
> the data source.
> Who's right and who's wrong here? :)
> Kind regards,
> Raymond
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
