[gdal-dev] GeoTiff with ColorInterp=Palette
Elena Ruiz eruiz at aplitop.com
Tue Feb 20 02:15:21 PST 2024
Hello, I have version 3.6.2 of GDAL and I need to crop an image using a contour from a GML file, so far there is no problem.
The problem begins when the original image is a GEOTIFF with transparency and it generates a cropped image, the information of both images is a little lower.
The color table changes from having 2 values to having 256, this causes it to lose transparency although it has the label "Mask Flags: PER_DATASET ALPHA" which indicates that it has an alpha channel.
My question is, why does the color table change?, and is there any parameter that can be used with gdalwarp or gdal_translate to avoid this and keep the image transparent?
I use this command:
gdalwarp.exe -cutline fichero.gml -crop_to_cutline -dstalpha ficheroIN ficheroOUT --config GDAL_DATA rutaGDAL
ORIGINAL IMAGE
Driver: GTiff/GeoTIFF
Size is 5616, 3655
Metadata:
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
  TIFFTAG_XRESOLUTION=300
  TIFFTAG_YRESOLUTION=300
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Band 1 Block=5616x1493 Type=Byte, ColorInterp=Palette
    NBITS=1
  Color Table (RGB with 2 entries)
    0: 0,0,0,255
    1: 255,255,255,255
CROPPED IMAGE
Size is 5605, 2689
Metadata:
  TIFFTAG_DATETIME=2024:02:09 08:49:12
  TIFFTAG_SOFTWARE=Microsoft Windows Photo Viewer 10.0.19041.1
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Band 1 Block=5605x1 Type=Byte, ColorInterp=Palette
  Color Table (RGB with 256 entries)
    0: 0,0,0,255
    1: 255,255,255,255
    2: 0,0,0,255
    3: 0,0,0,255
  252: 0,0,0,255
  253: 0,0,0,255
  254: 0,0,0,255
  255: 0,0,0,255
I await your response, thank you and regards.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240220/a893efcd/attachment-0001.htm>
