[gdal-dev] Antwort: Re: Build static GDAL-Lib and static GDAL-Apps
Kai Pastor, DG0YT dg0yt at darc.de
Tue Feb 20 04:12:17 PST 2024
When you install gdal[tools], the apps are installed to
`<install_root>/tools/gdal`.
(The vcpkg focus is on providing libs build from source.)
To explore port features, you can look at the port's vcpkg.json (aka
manifest), or start from
https://vcpkg.link/ports/gdal
Regards,
Kai
Am 20.02.24 um 12:22 schrieb Michael Otto via gdal-dev:
> Hi Robert,
> because I'm not getting anywhere with the "standard" CMake solution,
> I've now used the vcpkg you mentioned and am using it in a Virtualbox
> VM with Linux Mint.
> I got the installation instructions from here:
> https://github.com/microsoft/vcpkg?tab=readme-ov-file#quick-start-unix
> <https://github.com/microsoft/vcpkg?tab=readme-ov-file#quick-start-unix>.
> I have installed the Linux developer tools (see instructions).
> I have installed vcpkg under
> 'root at vmuser-VirtualBox:/home/vmuser/Git/vcpkg'.
> When installing the libraries, it seems that a lot of dependencies are
> also loaded, compiled and installed in the now large set of directories.
> The directory './vcpkg/packages/<packageName>_x64-linux' now contains
> the compiled static versions of the libraries. But where can I find
> the GDAL apps? These are not contained in this directory.
> I am still new to the topic of "self-compiling".
> Do you have any tips on what else I need to do?
> Michael
> Von: "Robert Coup" <robert.coup at koordinates.com>
> An: "Michael Otto" <michael.otto at data-experts.de>
> Kopie: gdal-dev at lists.osgeo.org
> Datum: 12.02.2024 15:43
> Betreff: Re: [gdal-dev] Build static GDAL-Lib and static GDAL-Apps
> Hi Michael,
> On Mon, 12 Feb 2024 at 12:02, Michael Otto via gdal-dev
> <_gdal-dev at lists.osgeo.org_ <mailto:gdal-dev at lists.osgeo.org>> wrote:
> The goal is to cast GDAL and all its dependencies (PROJ / GEOS / all
> dependencies to system libraries / ...) into a static library and to
> create the GDAL apps as static executable programs.
> Which platform are you working on? If you need a fully static
> compilation of everything /all/ the way down including openssl + zlib
> + zstd + libtiff + all the other libraries, using vcpkg[1] might be a
> reasonable approach. By default it does static compilation on macOS &
> Linux, and it has a static compilation option on Windows (the default
> on Windows is dynamic). It doesn't support every compile option
> though, but it's customisable and if you're after a reasonably vanilla
> GDAL it should work ok.
> There should be no dynamic dependencies.
> Note that GDAL + Proj (maybe others), have data files they rely on, so
> while you may be able to get a single executable, you'll still need to
> distribute these files. I can imagine ways around that, but they're
> getting fairly complex.
> Unfortunately, I have not had any success so far. The library is
> created statically but the apps are not yet.
> Does anyone have experience with this topic or possibly a procedure
> that leads to success?
> Can you share the process you've currently got to?
> Rob :)
> [1] _https://github.com/microsoft/vcpkg_
> <https://github.com/microsoft/vcpkg>
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240220/52fa219d/attachment.htm>
