[gdal-dev] Assert due to stack corruption in FlatGeoBuf export
Robert Coup robert.coup at koordinates.com
Tue Feb 20 13:49:15 PST 2024
On Tue, 20 Feb 2024 at 21:44, Robert Coup <robert.coup at koordinates.com>
wrote:
> Hi Simon,
> On Tue, 20 Feb 2024 at 21:11, Simon Eves <simon.eves at heavy.ai> wrote:
>> Here's the stack trace for the original assert. Something is stepping on
>> scratch_ to make it 0x1000000000 instead of null, which it starts out as
>> when the flatbuffer object is created, but by the time it gets to
>> allocating memory, it's broken.
> What happens if you set a watchpoint in gdb when the flatbuffer is created?
> watch -l myfb->scratch
> or watch *0x1234c0ffee
Or I've also had success with Mozilla's rr: https://rr-project.org/ — you
can run to a point where scratch is wrong, set a watchpoint on it, and then
run the program backwards to find out what touched it.
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240220/e314a9c9/attachment.htm>
