[gdal-dev] Some Tests fail in Actions tab of my branch
Abel Pau a.pau at creaf.uab.cat
Wed Feb 21 03:36:07 PST 2024
Ah ok!! Thanks Even.
I’ll review that, then! I didn’t though in that way
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dimecres, 21 de febrer de 2024 12:34
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Some Tests fail in Actions tab of my branch
Abel,
lately I’ve been solving some issues in my code to finally do a pull request of the MiraMon vector driver.
There some things about test in the action I don’t understand. I haven’t commit any test yet. So I assume it’s not my fault.
Anyone knows why some of them are failing?
You can see in the logs that it fails on autotest/ogr/ogr_basic_test.py::test_ogr_basic_10, and this test runs "test_ogrsf -all_drivers". As the name suggests, this test does some very minimal testing of all OGR drivers. I assume it must crash when running on the Miramon driver
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240221/1edb3174/attachment-0001.htm>
