[gdal-dev] Some Tests fail in Actions tab of my branch
Abel Pau a.pau at creaf.uab.cat
Wed Feb 21 05:44:20 PST 2024
Oh, you meant that!!
I’m gonna delete that file as it never existed :)
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dimecres, 21 de febrer de 2024 13:53
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Some Tests fail in Actions tab of my branch
Le 21/02/2024 à 13:44, Abel Pau a écrit :
I think there’ll be no problem about changing to MIT the code we want to add to GDAL.
I was talking about https://github.com/AbelPau/gdal/blob/master/ogr/ogrsf_frmts/miramon/COPYING
I just copied it from other place like ogr\ogrsf_frmts\mem\ogrmemlayer.cpp
There's no such file in the MEM driver. But perhaps you meant ogr/ogrsf_frmts/shape/COPYING . This is an old story with shapelib being *dual* licensed as LGPL or MIT at the option of the user. We should probably just opt for the MIT option for the shapelib copy in GDAL and remove the COPYING file from there. Actually just doing that per https://github.com/OSGeo/gdal/pull/9273.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240221/7fc2f491/attachment.htm>
