[gdal-dev] gdalinfo and WMS: is there a way to pass credentials via CLI?
Even Rouault even.rouault at spatialys.com
Fri Feb 23 09:27:50 PST 2024
I haven't tested but you should be able to use any of the env variable
listed for CPLHTTPFetch() at
https://gdal.org/api/cpl.html#_CPPv412CPLHTTPFetchPKc12CSLConstList
so here GDAL_HTTP_USERPWD
gdalinfo "WMS:http://wms.geobase.ca/wms-bin/cubeserv.cgi" --config
GDAL_HTTP_USERPWD user:password
And probably that just incorporating it in the URL should work:
gdalinfo "WMS:http://user:password@wms.geobase.ca/wms-bin/cubeserv.cgi"
Even
Le 23/02/2024 à 18:05, andy via gdal-dev a écrit :
> Hi,
> is there a way to pass UserPwd parameter via a gdalinfo command?
> Is there a way to pass it, without creating an XML file?
> Something like this
> -UserPwd user:password
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240223/9b060783/attachment.htm>
