[gdal-dev] gdalinfo and WMS: is there a way to pass credentials via CLI?
andy aborruso at gmail.com
Fri Feb 23 09:42:41 PST 2024
Thank you, it works great
On Fri, 23 Feb 2024 at 18:27, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I haven't tested but you should be able to use any of the env variable
> listed for CPLHTTPFetch() at
> https://gdal.org/api/cpl.html#_CPPv412CPLHTTPFetchPKc12CSLConstList
> so here GDAL_HTTP_USERPWD
> gdalinfo "WMS:http://wms.geobase.ca/wms-bin/cubeserv.cgi" --config
> GDAL_HTTP_USERPWD user:password
> And probably that just incorporating it in the URL should work:
> gdalinfo "WMS:http://user:password@wms.geobase.ca/wms-bin/cubeserv.cgi"
> Even
> Le 23/02/2024 à 18:05, andy via gdal-dev a écrit :
> Hi,
> is there a way to pass UserPwd parameter via a gdalinfo command?
> Is there a way to pass it, without creating an XML file?
> Something like this
> -UserPwd user:password
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
___________________
Andrea Borruso
___________________
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240223/2dac9945/attachment-0001.htm>
