[gdal-dev] Official dataset for benchmarking GDAL I/O?
Even Rouault even.rouault at spatialys.com
Sun Feb 25 04:25:44 PST 2024
Adam,
Automated performance regression testing is probably one of the aspect
of testing that could be enhanced. While the GDAL autotest suite is
quite comprehensive functionally wise, performance testing has
traditionally been a bit lagging. That said, this is an aspect we have
improved lately with the addition of a benchmark component to the
autotest suite
https://github.com/OSGeo/gdal/tree/master/autotest/benchmark . This is
admitedly quite minimalistic for now, but testing some scenarios
involving the GTiff driver and gdalwarp.
To test non-regression for a pull request, we have a CI benchmark
configuration
(https://github.com/OSGeo/gdal/blob/master/.github/workflows/linux_build.yml#L111
https://github.com/OSGeo/gdal/tree/master/.github/workflows/benchmarks)
that runs the benchmarks first against master, and then with the pull
request (during the same run of the same worker). But we need to allow a
quite large tolerance threshold (up to +20%) to take into account that
accurate timing measurements are extremely hard to get on CI
infrastructure (even locally, on microbenchmarks this is very
challenging). So this will mostly catch up big regressions, not subtle ones.
One of the difficulty with benchmark testing is that we don't want the
tests to run for hours, especially for pull requests, so they need to be
written in a careful way to still trigger the relevant code paths &
mechanisms of the code base that are exercised by real-world large
datasets while running in a few seconds each at most. Typically those
tests autogenerate their test data too, to avoid the test suite
depending on too large datasets and keep the repository size as small as
possible.
As you mention GPUs, we have had private contacts from a couple GPU
makers in recent years about potential GPU'ification of GDAL, but this
has lead to nowhere for now. Some mentioned that moving data acquisition
to the GPU could be interesting performance wise, but that seems to be a
huge undertaking, basically moving the GTiff driver, libtiff and its
codecs as GPU code. And even if done, how to manage the resulting code
duplication... We aren't even able to properly keep up the OpenCL warper
contributing many years ago in sync with the CPU warping code. We also
lack GPU expertise in the current team to do that.
Even
Le 25/02/2024 à 12:58, Adam Stewart via gdal-dev a écrit :
> Hi,
> *Background*: I'm the developer of the TorchGeo
> <https://github.com/microsoft/torchgeo> software library. TorchGeo is
> a machine learning library that heavily relies on GDAL (via
> rasterio/fiona) for satellite imagery I/O.
> One of our primary concerns is ensuring that we can load data from
> disk fast enough to keep the GPU busy during model training. Of
> course, satellite imagery is often distributed in large files that
> make this challenging. We use various tricks to optimize performance
> (COGs, windowed reading, caching, compression, parallel workers,
> etc.). In our initial paper <https://arxiv.org/abs/2111.08872>, we
> chose to create our own arbitrary I/O benchmarking dataset composed of
> 100 Landsat scenes and 1 CDL map. See Figure 3 for the results, and
> Appendix A for the experiment details.
> *Question*: is there an official dataset that the GDAL developers use
> to benchmark GDAL itself? For example, if someone makes a change to
> how GDAL handles certain I/O operations, I assume the GDAL developers
> will benchmark it to see if I/O is now faster or slower. I'm
> envisioning experiments similar to
> https://kokoalberti.com/articles/geotiff-compression-optimization-guide/
> for various file formats, compression levels, block sizes, etc.
> If such a dataset doesn't yet exist, I would be interested in creating
> one and publishing a paper on how this can be used to develop
> libraries like GDAL and TorchGeo.
> *Dr. Adam J. Stewart*
> Technical University of Munich
> School of Engineering and Design
> Data Science in Earth Observation
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240225/3fde13b3/attachment.htm>
