[gdal-dev] Official dataset for benchmarking GDAL I/O?
Adam Stewart adam.stewart at tum.de
Sun Feb 25 03:58:43 PST 2024
Background: I'm the developer of the TorchGeo<https://github.com/microsoft/torchgeo> software library. TorchGeo is a machine learning library that heavily relies on GDAL (via rasterio/fiona) for satellite imagery I/O.
One of our primary concerns is ensuring that we can load data from disk fast enough to keep the GPU busy during model training. Of course, satellite imagery is often distributed in large files that make this challenging. We use various tricks to optimize performance (COGs, windowed reading, caching, compression, parallel workers, etc.). In our initial paper<https://arxiv.org/abs/2111.08872>, we chose to create our own arbitrary I/O benchmarking dataset composed of 100 Landsat scenes and 1 CDL map. See Figure 3 for the results, and Appendix A for the experiment details.
Question: is there an official dataset that the GDAL developers use to benchmark GDAL itself? For example, if someone makes a change to how GDAL handles certain I/O operations, I assume the GDAL developers will benchmark it to see if I/O is now faster or slower. I'm envisioning experiments similar to https://kokoalberti.com/articles/geotiff-compression-optimization-guide/ for various file formats, compression levels, block sizes, etc.
If such a dataset doesn't yet exist, I would be interested in creating one and publishing a paper on how this can be used to develop libraries like GDAL and TorchGeo.
Dr. Adam J. Stewart
Technical University of Munich
School of Engineering and Design
Data Science in Earth Observation
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240225/515dccb4/attachment-0001.htm>
