[gdal-dev] layer creation option shapefile when converting arcs in dxf
Jan Heckman jan.heckman at gmail.com
Sat Feb 24 11:21:57 PST 2024
Even,
Thanks, that does the job.
I'll lookup configuration options first next time!
Jan
On Sat, Feb 24, 2024 at 12:20 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> perhaps the OGR_ARC_STEPSIZE configuration option:
> https://gdal.org/user/configoptions.html#config-OGR_ARC_STEPSIZE ?
> Even
> Le 24/02/2024 à 12:15, Jan Heckman via gdal-dev a écrit :
> > Hi All,
> > I am looking for a way to influence the (density of the) linestrings
> > which are produced by converting a circle segment in dxf (to a
> > linestring in shapefile format); the aim, ideally, is to limit the
> > angle(s) between the chords produced.
> > If not available, a setting of the number of vertices for a circle
> > would also help.
> > I searched docs, and if I overlooked, apologies in advance.
> > I am hoping for a setting for ogr2ogr, but also interested in a
> > solution using the (C++) api/library.
> > thanks, Jan
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240224/11275c6b/attachment-0001.htm>
