[gdal-dev] layer creation option shapefile when converting arcs in dxf
Even Rouault even.rouault at spatialys.com
Sat Feb 24 03:19:59 PST 2024
perhaps the OGR_ARC_STEPSIZE configuration option:
https://gdal.org/user/configoptions.html#config-OGR_ARC_STEPSIZE ?
Even
Le 24/02/2024 à 12:15, Jan Heckman via gdal-dev a écrit :
> Hi All,
> I am looking for a way to influence the (density of the) linestrings
> which are produced by converting a circle segment in dxf (to a
> linestring in shapefile format); the aim, ideally, is to limit the
> angle(s) between the chords produced.
> If not available, a setting of the number of vertices for a circle
> would also help.
> I searched docs, and if I overlooked, apologies in advance.
> I am hoping for a setting for ogr2ogr, but also interested in a
> solution using the (C++) api/library.
> thanks, Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
