[gdal-dev] Some problems after updating
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Feb 27 00:57:29 PST 2024
Hi Abel,
If you have clear when it started happening, maybe you can try to find the
reason using https://git-scm.com/docs/git-bisect
specially as you are reproducing it in your computer (CI is working fine,
so that should be something related to your configuration).
Replicate it working fine with an older checkout from the repo, then
replicate it failing today, and look for the change that "breaks" it.
If you cannot replicate the correct behaviour with an older checkout...
then the problem is not the source code.
Cheers,
Javier.
On Tue, 27 Feb 2024 at 09:15, Abel Pau via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi again,
> I built and compiled the Gdal version in GitHub (without my changes) and
> the error is NOT gone.
> Anyone has compiled very recently and is capable to call ogr2ogr with no
> problems?
> Thanks
> *De:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel Pau
> via gdal-dev
> *Enviado el:* dilluns, 26 de febrer de 2024 18:17
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> *Asunto:* Re: [gdal-dev] Some problems after updating
> Done but it doesn’t work.
> The error is the same.
> Any other idea?
> *De:* Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dilluns, 26 de febrer de 2024 17:55
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Perhaps try the good old methods: run the "clean" target and do a full
> rebuild
> Le 26/02/2024 à 17:48, Abel Pau via gdal-dev a écrit :
> It even now doesn’t work from Visual Studio itself.
> I don’t understand what have changed from yesterday to today (apart from
> updating vcpkg and gdal code itself).
> <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel Pau via gdal-dev
> *Enviado el:* dilluns, 26 de febrer de 2024 17:42
> <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> Hi Even, thanks for your answer.
> I paste here some of my variables:
> After too many months perhaps there are things that are not necessary, but
> the one you sais is there:
> *GDAL_DATA *
> D:\GitHub-repository\GDAL\build\data
> *PATH *
> PATH%;
> D:\GitHub-repository\GDAL\build\Debug;
> C:\Users\a.pau\AppData\Local\GitHubDesktop\bin;
> C:\Program Files\Graphviz\bin;
> D:\GitHub-repository\odbc-cpp-wrapper\build\src\odbc\Release;
> D:\mapes\programes\make-3.81-bin\bin;
> But same error appears :(
> *Enviado el:* dilluns, 26 de febrer de 2024 17:30
> hi,
> perhaps make sure that your PATH environment variable includes a directory
> that contains the gdal.dll of *your* build (should likely be
> D:\GitHub-repository\GDAL\build\Debug) before the one potentially coming
> from vcpkg
> Even
> Le 26/02/2024 à 17:20, Abel Pau via gdal-dev a écrit :
> Hi,
> usually (and always works) I call this two sentences from command line in
> Windows:
> cmake -B D:\GitHub-repository\GDAL\build -S .
> -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake
> cmake --build D:\GitHub-repository\GDAL\build
> The first one generates all projects that I can open with Visual Studio
> The second one compilates all files, and it ens with no problems.
> To test is works I’ve been using lots of line commands, for example this
> one (using the program ogr2ogr):
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe
> D:\mapes\2023\GDAL\Versions\Misteri_V20_a_V11.pol
> D:\mapes\2023\GDAL\Versions\Misteri_V20.pol -progress -lco Version=V1.1
> --config CPL_DEBUG ON
> It’s been working untiel today when next error appears:
> ogr2ogr.exe - No se encuentra el punto de entrada
> No se encuentra el punto de entrada del procedimiento
> ?TransformWithErrorCodes at OGRCoordinateTransformation@@UEAAH_KPEAN111PEAH at Z
> en la biblioteca de vínculos dinámicos
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe.
> D'acord
> What is the diference between today and yesterday?
> I’ve done 2 things:
> 1.       Download and Install VCPKG (the method that worked for me)
> 2.       .\vcpkg\bootstrap-vcpkg.bat
> 3.       .\vcpkg integrate install
> 4.       .\vcpkg install gdal --triplet=x64-windows
> And, of course, download lasts codes from GDAL to be on date before
> finishing the job I’m doing.
> So, can anyone put some light to this mistery? What I am doing wrong this
> time?
> There is some dependence I am using wrong?
> I am a little desperate with that kind of errors.
> Thanks a lot!
> *Abel Pau Garcia*
> *GIS developer*
> [image: https://www.creaf.cat/sites/default/files/creaf-signature.png]
> *a.pau at creaf.uab.cat* <a.pau at creaf.uab.cat>
> *Let's chat on Teams!*
> <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
> *Tel. +34 934814277*
> [image: https://www.creaf.cat/sites/default/files/so-en-signature.png]
> [image:
> https://www.creaf.cat/sites/default/files/twitter-icon-signature.png]
> <https://twitter.com/CREAF_ecologia>[image:
> https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png]
> <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>[image:
> https://www.creaf.cat/sites/default/files/youtube-icon-signature.png]
> <https://www.youtube.com/c/creafecologia>[image:
> https://www.creaf.cat/sites/default/files/instagram-icon-signature.png]
> <https://www.instagram.com/CREAF_ecologia/>
> *www.creaf.cat* <http://www.creaf.cat>* | **http://blog.creaf.cat*
> <http://blog.creaf.cat>
> [image: https://www.creaf.cat/sites/default/files/uab_logo_signatura.png]
> CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
> Before printing this electronic message, think about the environment.
> [image: http://www.creaf.uab.cat/_signatura/line.gif]
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0011.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/0825bf7f/attachment-0003.jpg>
