[gdal-dev] Some problems after updating
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Feb 27 01:17:39 PST 2024
ohhhh, Windows debug. That was not easy (when I worked in Windows, more
than 10 years ago). It is using different names for libraries in debug and
release.
 'ogr_VDV.dir\Debug\ogr_VDV.lib':  could you check that is the content of
that directory? I wouldn't be surprised if the library file there has a
slightly different name.
On Tue, 27 Feb 2024 at 10:06, Abel Pau <a.pau at creaf.uab.cat> wrote:
> Hi Javier,
> I did two changes at the same time (bad  bad, never do that!): one
> updating the code from repo (as usual) and the other one updating vcpkg
> (cause there like 1000 changes in their Git and I though that was a good
> idea).
> I suspect the code is good but I’ll make sure doing that bisection method.
> Even though this error is rare:
> 3>LINK : fatal error LNK1104: cannot open file
> 3>Done building project "ogr_VDV.vcxproj" -- FAILED.
> I wonder why it is not writing (ogr_VDV it’s the only one that have the
> error).
> Thanks!
> *De:* Javier Jimenez Shaw <j1 at jimenezshaw.com>
> *Enviado el:* dimarts, 27 de febrer de 2024 9:57
> *Para:* Abel Pau <a.pau at creaf.uab.cat>
> *CC:* gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Some problems after updating
> Hi Abel,
> If you have clear when it started happening, maybe you can try to find the
> reason using https://git-scm.com/docs/git-bisect
> specially as you are reproducing it in your computer (CI is working fine,
> so that should be something related to your configuration).
> Replicate it working fine with an older checkout from the repo, then
> replicate it failing today, and look for the change that "breaks" it.
> If you cannot replicate the correct behaviour with an older checkout...
> then the problem is not the source code.
> Cheers,
> Javier.
> On Tue, 27 Feb 2024 at 09:15, Abel Pau via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
> Hi again,
> I built and compiled the Gdal version in GitHub (without my changes) and
> the error is NOT gone.
> Anyone has compiled very recently and is capable to call ogr2ogr with no
> problems?
> Thanks
> *De:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel Pau
> via gdal-dev
> *Enviado el:* dilluns, 26 de febrer de 2024 18:17
> *Para:* Even Rouault <even.rouault at spatialys.com>;
> Done but it doesn’t work.
> The error is the same.
> Any other idea?
> *De:* Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* dilluns, 26 de febrer de 2024 17:55
> *Para:* Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
> Perhaps try the good old methods: run the "clean" target and do a full
> rebuild
> Le 26/02/2024 à 17:48, Abel Pau via gdal-dev a écrit :
> It even now doesn’t work from Visual Studio itself.
> I don’t understand what have changed from yesterday to today (apart from
> updating vcpkg and gdal code itself).
> <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Abel Pau via gdal-dev
> *Enviado el:* dilluns, 26 de febrer de 2024 17:42
> <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> Hi Even, thanks for your answer.
> I paste here some of my variables:
> After too many months perhaps there are things that are not necessary, but
> the one you sais is there:
> *GDAL_DATA *
> D:\GitHub-repository\GDAL\build\data
> *PATH *
> PATH%;
> D:\GitHub-repository\GDAL\build\Debug;
> C:\Users\a.pau\AppData\Local\GitHubDesktop\bin;
> C:\Program Files\Graphviz\bin;
> D:\GitHub-repository\odbc-cpp-wrapper\build\src\odbc\Release;
> D:\mapes\programes\make-3.81-bin\bin;
> But same error appears :(
> *Enviado el:* dilluns, 26 de febrer de 2024 17:30
> hi,
> perhaps make sure that your PATH environment variable includes a directory
> that contains the gdal.dll of *your* build (should likely be
> D:\GitHub-repository\GDAL\build\Debug) before the one potentially coming
> from vcpkg
> Even
> Le 26/02/2024 à 17:20, Abel Pau via gdal-dev a écrit :
> Hi,
> usually (and always works) I call this two sentences from command line in
> Windows:
> cmake -B D:\GitHub-repository\GDAL\build -S .
> -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake
> cmake --build D:\GitHub-repository\GDAL\build
> The first one generates all projects that I can open with Visual Studio
> The second one compilates all files, and it ens with no problems.
> To test is works I’ve been using lots of line commands, for example this
> one (using the program ogr2ogr):
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe
> D:\mapes\2023\GDAL\Versions\Misteri_V20_a_V11.pol
> D:\mapes\2023\GDAL\Versions\Misteri_V20.pol -progress -lco Version=V1.1
> --config CPL_DEBUG ON
> It’s been working untiel today when next error appears:
> ogr2ogr.exe - No se encuentra el punto de entrada
> No se encuentra el punto de entrada del procedimiento
> ?TransformWithErrorCodes at OGRCoordinateTransformation@@UEAAH_KPEAN111PEAH at Z
> en la biblioteca de vínculos dinámicos
> D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe.
> D'acord
> What is the diference between today and yesterday?
> I’ve done 2 things:
> 1.       Download and Install VCPKG (the method that worked for me)
> 2.       .\vcpkg\bootstrap-vcpkg.bat
> 3.       .\vcpkg integrate install
> 4.       .\vcpkg install gdal --triplet=x64-windows
> And, of course, download lasts codes from GDAL to be on date before
> finishing the job I’m doing.
> So, can anyone put some light to this mistery? What I am doing wrong this
> time?
> There is some dependence I am using wrong?
> I am a little desperate with that kind of errors.
> Thanks a lot!
> *Abel Pau Garcia*
> *GIS developer*
> [image: https://www.creaf.cat/sites/default/files/creaf-signature.png]
> *a.pau at creaf.uab.cat* <a.pau at creaf.uab.cat>
> *Let's chat on Teams!*
> <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
> *Tel. +34 934814277*
> [image: https://www.creaf.cat/sites/default/files/so-en-signature.png]
> [image:
> https://www.creaf.cat/sites/default/files/twitter-icon-signature.png]
> <https://twitter.com/CREAF_ecologia>[image:
> https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png]
> <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>[image:
> https://www.creaf.cat/sites/default/files/youtube-icon-signature.png]
> <https://www.youtube.com/c/creafecologia>[image:
> https://www.creaf.cat/sites/default/files/instagram-icon-signature.png]
> <https://www.instagram.com/CREAF_ecologia/>
> *www.creaf.cat* <http://www.creaf.cat>* | **http://blog.creaf.cat*
> <http://blog.creaf.cat>
> [image: https://www.creaf.cat/sites/default/files/uab_logo_signatura.png]
> CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
> Before printing this electronic message, think about the environment.
> [image: http://www.creaf.uab.cat/_signatura/line.gif]
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0011.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/80e18edf/attachment-0003.jpg>
