[gdal-dev] Some problems after updating
Abel Pau a.pau at creaf.uab.cat
Tue Feb 27 02:34:54 PST 2024
sure it’s a good point going through that way.
Thanks!
De: Javier Jimenez Shaw <j1 at jimenezshaw.com>
Enviado el: dimarts, 27 de febrer de 2024 11:15
Para: Abel Pau <a.pau at creaf.uab.cat>
CC: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Some problems after updating
I am not an expert in Windows at all. But the message says that cannot find "TransformWithErrorCodes...blablah" in ogr2gr.exe. Could it be that this method is actually in a dll, and the dll is not found? can be a PATH problem? There are tools to see the exported methods from a dll. Check that it does exist, and that is findable by ogr2ogr.exe.
On Tue, 27 Feb 2024 at 10:43, Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>> wrote:
In one month ago gdal code the error persists.
So I have to conclude that this error is related to my vcpkg update with, so I’m sad because it’s not something easy to solve.
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> En nombre de Abel Pau via gdal-dev
Enviado el: dimarts, 27 de febrer de 2024 10:29
Para: Javier Jimenez Shaw <j1 at jimenezshaw.com<mailto:j1 at jimenezshaw.com>>
CC: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Ups, forget this compilation error (not the first one).
The directory exists and another program (by error) had it opened causing the compiler couldn’t delete it.
So, it was my mistake.
So, I’m going to proceed with that one:
De: Javier Jimenez Shaw <j1 at jimenezshaw.com<mailto:j1 at jimenezshaw.com>>
Enviado el: dimarts, 27 de febrer de 2024 10:18
Para: Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>
ohhhh, Windows debug. That was not easy (when I worked in Windows, more than 10 years ago). It is using different names for libraries in debug and release.
 'ogr_VDV.dir\Debug\ogr_VDV.lib':  could you check that is the content of that directory? I wouldn't be surprised if the library file there has a slightly different name.
On Tue, 27 Feb 2024 at 10:06, Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>> wrote:
Hi Javier,
I did two changes at the same time (bad  bad, never do that!): one updating the code from repo (as usual) and the other one updating vcpkg (cause there like 1000 changes in their Git and I though that was a good idea).
I suspect the code is good but I’ll make sure doing that bisection method.
Even though this error is rare:
3>LINK : fatal error LNK1104: cannot open file 'ogr_VDV.dir\Debug\ogr_VDV.lib'
3>Done building project "ogr_VDV.vcxproj" -- FAILED.
I wonder why it is not writing (ogr_VDV it’s the only one that have the error).
Thanks!
Enviado el: dimarts, 27 de febrer de 2024 9:57
Hi Abel,
If you have clear when it started happening, maybe you can try to find the reason using https://git-scm.com/docs/git-bisect
specially as you are reproducing it in your computer (CI is working fine, so that should be something related to your configuration).
Replicate it working fine with an older checkout from the repo, then replicate it failing today, and look for the change that "breaks" it.
If you cannot replicate the correct behaviour with an older checkout... then the problem is not the source code.
Cheers,
Javier.
On Tue, 27 Feb 2024 at 09:15, Abel Pau via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Hi again,
I built and compiled the Gdal version in GitHub (without my changes) and the error is NOT gone.
Anyone has compiled very recently and is capable to call ogr2ogr with no problems?
Thanks
Enviado el: dilluns, 26 de febrer de 2024 18:17
Para: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Done but it doesn’t work.
The error is the same.
Any other idea?
De: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Enviado el: dilluns, 26 de febrer de 2024 17:55
Para: Abel Pau <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Perhaps try the good old methods: run the "clean" target and do a full rebuild
Le 26/02/2024 à 17:48, Abel Pau via gdal-dev a écrit :
It even now doesn’t work from Visual Studio itself.
I don’t understand what have changed from yesterday to today (apart from updating vcpkg and gdal code itself).
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org><mailto:gdal-dev-bounces at lists.osgeo.org> En nombre de Abel Pau via gdal-dev
Enviado el: dilluns, 26 de febrer de 2024 17:42
Para: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Hi Even, thanks for your answer.
I paste here some of my variables:
After too many months perhaps there are things that are not necessary, but the one you sais is there:
GDAL_DATA
D:\GitHub-repository\GDAL\build\data
PATH
PATH%;
D:\GitHub-repository\GDAL\build\Debug;
C:\Users\a.pau\AppData\Local\GitHubDesktop\bin;
C:\Program Files\Graphviz\bin;
D:\GitHub-repository\odbc-cpp-wrapper\build\src\odbc\Release;
D:\mapes\programes\make-3.81-bin\bin;
But same error appears :(
Enviado el: dilluns, 26 de febrer de 2024 17:30
hi,
perhaps make sure that your PATH environment variable includes a directory that contains the gdal.dll of *your* build (should likely be D:\GitHub-repository\GDAL\build\Debug) before the one potentially coming from vcpkg
Even
Le 26/02/2024 à 17:20, Abel Pau via gdal-dev a écrit :
usually (and always works) I call this two sentences from command line in Windows:
cmake -B D:\GitHub-repository\GDAL\build -S . -DCMAKE_TOOLCHAIN_FILE=C:/dev/vcpkg/vcpkg/scripts/buildsystems/vcpkg.cmake
cmake --build D:\GitHub-repository\GDAL\build
The first one generates all projects that I can open with Visual Studio
The second one compilates all files, and it ens with no problems.
To test is works I’ve been using lots of line commands, for example this one (using the program ogr2ogr):
D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe D:\mapes\2023\GDAL\Versions\Misteri_V20_a_V11.pol D:\mapes\2023\GDAL\Versions\Misteri_V20.pol -progress -lco Version=V1.1 --config CPL_DEBUG ON
It’s been working untiel today when next error appears:
ogr2ogr.exe - No se encuentra el punto de entrada
No se encuentra el punto de entrada del procedimiento ?TransformWithErrorCodes at OGRCoordinateTransformation@@UEAAH_KPEAN111PEAH at Z en la biblioteca de vínculos dinámicos D:\GitHub-repository\GDAL\build\apps\Debug\ogr2ogr.exe.
D'acord
What is the diference between today and yesterday?
I’ve done 2 things:
1.       Download and Install VCPKG (the method that worked for me)
2.       .\vcpkg\bootstrap-vcpkg.bat
3.       .\vcpkg integrate install
4.       .\vcpkg install gdal --triplet=x64-windows
And, of course, download lasts codes from GDAL to be on date before finishing the job I’m doing.
So, can anyone put some light to this mistery? What I am doing wrong this time?
There is some dependence I am using wrong?
I am a little desperate with that kind of errors.
Thanks a lot!
Abel Pau Garcia
GIS developer
[https://www.creaf.cat/sites/default/files/creaf-signature.png]
Let's chat on Teams!<https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/so-en-signature.png]
[https://www.creaf.cat/sites/default/files/twitter-icon-signature.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png]<https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>[https://www.creaf.cat/sites/default/files/youtube-icon-signature.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram-icon-signature.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat<http://www.creaf.cat> | http://blog.creaf.cat
[https://www.creaf.cat/sites/default/files/uab_logo_signatura.png]
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
Before printing this electronic message, think about the environment.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0006.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0007.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0009.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0010.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0011.png>
Type: image/jpeg
Desc: image007.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0002.jpg>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c1ee30e4/attachment-0003.jpg>
