[gdal-dev] Antwort: Re: Segmentation fault (core dumped) in gdal_translate & ogrinfo & ogr2ogr
Michael Otto michael.otto at data-experts.de
Tue Feb 27 05:01:45 PST 2024
Hello Robert,
I have now been able to find the error myself.
I forgot to set the proxy in the Docker container. After I added it, it
also worked under Fedora.
Now I'm stuck under Ubuntu 20.04. There comes the next error :o( :
ERROR 1: error setting certificate file:
/etc/ssl/certs/ca-certificates.crt
ERROR 1: Error returned by server : error setting certificate file:
/etc/ssl/certs/ca-certificates.crt (77)
ogrinfo failed - unable to open 'WFS:https://........'.
Michael
PS:
I built Gdal under Linux Mint 21.3 (Virginia).
The host system for the Docker containers is Ubuntu 22.04.3 LTS (Jammy
Jellyfish).
Von:    "Robert Coup" <robert.coup at koordinates.com>
An:     "Michael Otto" <michael.otto at data-experts.de>
Kopie:  gdal-dev at lists.osgeo.org
Datum:  27.02.2024 13:14
Betreff:        Re: [gdal-dev] Segmentation fault (core dumped) in
Hi Michael,
On Tue, 27 Feb 2024 at 11:40, Michael Otto via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
with a lot of effort and support from this group I created a first static
version of GDAL (incl. the apps) under Linux x64 using vcpkg.
Yay
For testing I copied the built apps and the data files to different target
platforms and set the environment variables accordingly.
In a current Linux Mint VM and in an Alpine Linux 3.13 Docker container,
the command line calls worked perfectly.
What system did you build gdal on/under?
Under a Fedora Linux 39 Docker container (docker pull fedora, ...) an
error occurs when executing ogrinfo, ogr2ogr and gdal_translate (the other
tools were not tested):
What's the host OS?
Does anyone have an idea or know what the problem is?
What does a backtrace from gdb produce?
$ gdb --args ogrinfo
... loading stuff
(gdb) run
Program received signal SIGSEGV, Segmentation fault.
0x12c0ffee in _a_function ()
(gdb) thread apply all backtrace
... the backtrace ...
(gdb) quit
Use the gdal tools from the installed/{platform}/tools/gdal/debug/ vcpkg
build folder, they're more likely to produce readable traces.
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/c661d810/attachment.htm>
