[gdal-dev] Segmentation fault (core dumped) in gdal_translate & ogrinfo & ogr2ogr
Robert Coup robert.coup at koordinates.com
Tue Feb 27 04:13:56 PST 2024
Hi Michael,
On Tue, 27 Feb 2024 at 11:40, Michael Otto via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> with a lot of effort and support from this group I created a first static
> version of GDAL (incl. the apps) under Linux x64 using vcpkg.
Yay
> For testing I copied the built apps and the data files to different target
> platforms and set the environment variables accordingly.
> In a current Linux Mint VM and in an Alpine Linux 3.13 Docker container,
> the command line calls worked perfectly.
What system did you build gdal on/under?
> Under a Fedora Linux 39 Docker container (docker pull fedora, ...) an
> error occurs when executing ogrinfo, ogr2ogr and gdal_translate (the other
> tools were not tested):
What's the host OS?
> Does anyone have an idea or know what the problem is?
What does a backtrace from gdb produce?
$ gdb --args ogrinfo
... loading stuff
(gdb) run
Program received signal SIGSEGV, Segmentation fault.
0x12c0ffee in _a_function ()
(gdb) thread apply all backtrace
... the backtrace ...
(gdb) quit
Use the gdal tools from the installed/{platform}/tools/gdal/debug/ vcpkg
build folder, they're more likely to produce readable traces.
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240227/3e8f6808/attachment.htm>
