[gdal-dev] Where to fins my own files
Even Rouault even.rouault at spatialys.com
Sun Jan 7 03:20:16 PST 2024
Yes, the practice for a resource file is:
- put it under data/
- add it to the GDAL_DATA_FILES variable on top level gdal.cmake file
- use CPLFindFile("gdal", "your.file") to get its path
Le 07/01/2024 à 01:59, Sean Gillies via gdal-dev a écrit :
> Happy New Year to you too, Abel.
> Other drivers, such as PCI and NITF,  include some files in the data
> directory.  See https://github.com/OSGeo/gdal/tree/master/data.
> Distributions generally copy these to $prefix/share/gdal on unix-like
> systems. I'm not aware of a practice of copying data out of a driver's
> directory to that same location, though it's probably possible with
> Cmake. Your driver's own directory won't necessarily exist on a system
> where you install GDAL.
> For datum files, have you checked whether they already exist in the
> PROJ project?
> On Sat, Jan 6, 2024, 2:32 PM Abel Pau via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
>     Hi,
>     Happy New 2024 to everyone who celebrates it!
>     I am programming a driver and in some point I need to read a file
>     that contains some information (and it’s better to keep this in a
>     file than in c code) about the Horizontal Reference System.
>     I have this file here: “GDAL\ogr\ogrsf_frmts\miramon”, but when
>     coding I don’t know how to get to this folder.
>     There is any method to open a file (using VSIFOpenL(), for
>     instance) in THIS specific directory? Can I use
>     “GDAL\ogr\ogrsd_frmts\miramon” like that?
>     If not, where can I put this file to be found when executing the
>     code? And how to write this path in the code?
>     Thanks in advance!!
>     *Abel Pau Garcia*
>     *GIS developer*
>     https://www.creaf.cat/sites/default/files/creaf-signature.png
>     *a.pau at creaf.uab.cat* <mailto:a.pau at creaf.uab.cat>
>     *Let's chat on Teams!*
>     <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
>     *Tel. +34 934814277*
>     https://www.creaf.cat/sites/default/files/so-en-signature.png
>     https://www.creaf.cat/sites/default/files/twitter-icon-signature.png
>     <https://twitter.com/CREAF_ecologia>https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png
>     <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>https://www.creaf.cat/sites/default/files/youtube-icon-signature.png
>     <https://www.youtube.com/c/creafecologia>https://www.creaf.cat/sites/default/files/instagram-icon-signature.png
>     <https://www.instagram.com/CREAF_ecologia/>
>     *www.creaf.cat* <http://www.creaf.cat>*| **http://blog.creaf.cat*
>     <http://blog.creaf.cat>
>     https://www.creaf.cat/sites/default/files/uab_logo_signatura.png
>     CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
>     Before printing this electronic message, think about the environment.
>     http://www.creaf.uab.cat/_signatura/line.gif
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240107/5703293a/attachment-0001.htm>
