[gdal-dev] Is source Dataset array to `GDALWarp` mutable?
    Even Rouault
    even.rouault at spatialys.com
    Tue Jan  9 10:53:32 PST 2024
Le 09/01/2024 à 19:45, Fitch, Simeon via gdal-dev a écrit :
> I have a question about the mutability of the `pahSrcDS` argument to
> `GDALWarp`.
> The `GDALWarp` function has the following signature:
> GDALDatasetH GDALWarp(const char *pszDest, GDALDatasetH hDstDS, int
> nSrcCount,
>                       GDALDatasetH *pahSrcDS,
>                       const GDALWarpAppOptions *psOptionsIn, int
> *pbUsageError)
> Source:
> https://github.com/OSGeo/gdal/blob/895e9fbd63b2aa22471f4f8c69efd5ba4e700e9c/apps/gdalwarp_lib.cpp#L1379-L1381
> I was curious to see that `pahSrcDS` was not `const GDALDatasetH
> *pahSrcDS` or `const GDALDatasetH * const pahSrcDS`.
> What mutability and ownership conclusions should I draw from it (if any)?
> * Might the `GDALWarp` mutate the array and/or the pointed Datasets?
No. The const correctness could have indeed be done better (although a
reason for that is that in C, a  "T**" is not implicitly cast as "const
T* const*", contrary to C++)
> * Is it correct to assume the caller maintains ownership of the
> elements of `pahSrcDS`?
Yes
Note that if the output format is VRT, then the return VRT dataset will
reference the input dataset handle (a single one is allowed in that
case). Hence, in that particular case (works also in the general case),
you should close first the output dataset and then source dataset(s), as
done by gdalwarp_bin.cpp
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240109/569a40d6/attachment.htm>
