[gdal-dev] Lack of srs importFromESRI integer function
Even Rouault even.rouault at spatialys.com
Wed Jan 10 09:48:37 PST 2024
Jesse,
You can use SetFromUserInput("ESRI:XXXX")  . ImportFromEPSG(code) more
or less does SetFromUserInput("EPSG:{code}")
Even
Le 10/01/2024 à 18:44, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> Our team has moved away from providing geographic / projected CRS
> codes as strings and prefer using integers where possible.  However,
> in the C++ API, I only see an integer based importFromEPSG function,
> which doesn’t appear to accept ESRI codes (crs not found error
> message).  We’re targeting an Albers projection which is distinguished
> by an ESRI integer.
> Curiously, the proj database doesn’t seem to make this distinction –
> the table column is simply ‘code’ and I can find the projection row
> manually, alongside EPSG projections.
> Can such a function be provided by the API (if it doesn’t already
> exist – I couldn’t find it – there are no integer overloads of
> importFromESRI)?
> Please advise -- thanks,
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240110/2e3029db/attachment.htm>
