[gdal-dev] Issue with OGR Brush Styling for PDF Generation
Even Rouault even.rouault at spatialys.com
Fri Jan 12 08:08:33 PST 2024
as documented in
https://gdal.org/drivers/vector/pdf.html#feature-style-support, styling
support in the PDF driver is very limited, and doesn't include the brush
type. For things not supported, you'd better use a more advanced
rendering engine that can output PDF, like QGIS or MapServer
Even
Le 12/01/2024 à 11:53, Mandeep Singh via gdal-dev a écrit :
> Hi,
> I am facing challenges in using the OGR Brush symbols for PDF
> generation and only the default styling seems to be working. It seems
> the id:"ogr-brush-n" is not considered.
> GDAL version is  3.2.2
> Can anyone provide any feedback ?
> Regards
> Mandeep
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240112/5aa2c65a/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240112/5aa2c65a/attachment-0001.png>
