[gdal-dev] Issue with OGR Brush Styling for PDF Generation
Mandeep Singh mandeepsinghkalra at gmail.com
Mon Jan 15 00:36:04 PST 2024
Thanks Even.
Unfortunately i can't use these engines as i am trying to build it
independently.
Is there any way using GDAL i can convert a polygon shape file to a
patterned area like ogr-brush5 ?
Which can then be added on PDF as a vector/raster ?
Regards
Mandeep
On Fri, Jan 12, 2024 at 9:38 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> as documented in
> https://gdal.org/drivers/vector/pdf.html#feature-style-support, styling
> support in the PDF driver is very limited, and doesn't include the brush
> type. For things not supported, you'd better use a more advanced rendering
> engine that can output PDF, like QGIS or MapServer
> Even
> Le 12/01/2024 à 11:53, Mandeep Singh via gdal-dev a écrit :
> Hi,
> I am facing challenges in using the OGR Brush symbols for PDF generation
> and only the default styling seems to be working. It seems the
> id:"ogr-brush-n" is not considered.
> [image: image.png]
> GDAL version is  3.2.2
> Can anyone provide any feedback ?
> Regards
> Mandeep
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240115/9b7739eb/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240115/9b7739eb/attachment-0001.png>
