[gdal-dev] Using VSIMEM properly
Laurențiu Nicola lnicola at dend.ro
Wed Jan 17 04:35:07 PST 2024
Hei :-),
Nope, I think those are the only options:
 • save the output into a (real) file
 • keep using vsimem, but chain the operations while the app is still running
Do you have any particular reason to use vsimem?
Laurentiu
On Wed, Jan 17, 2024, at 14:00, nagyrobi_r at yahoo.com wrote:
> Hei Laurențiu! Thank you for yor email!
> Is there a way to pipe these operations or do anything fancy to be able to sit outside of a programming environment?
> Cu respect,
> Robert Nagy
> Sent from Yahoo Mail on Android <https://mail.onelink.me/107872968?pid=nativeplacement&c=Global_Acquisition_YMktg_315_Internal_EmailSignature&af_sub1=Acquisition&af_sub2=Global_YMktg&af_sub3=&af_sub4=100000604&af_sub5=EmailSignature__Static_>
>> On Wed, Jan 17, 2024 at 11:59 AM, Laurențiu Nicola via gdal-dev
>> <gdal-dev at lists.osgeo.org> wrote:
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240117/f6746a61/attachment.htm>
