[gdal-dev] Using VSIMEM properly
nagyrobi_r at yahoo.com nagyrobi_r at yahoo.com
Wed Jan 17 05:51:00 PST 2024
Technically in want to save time by not saving to disk. That is one of the main reasons that i want to save in memory. I tried chaning them using pipes but didnt work.
Cu respect, Robert Nagy
Sent from Yahoo Mail on Android
  On Wed, Jan 17, 2024 at 1:35 PM, Laurențiu Nicola<lnicola at dend.ro> wrote:
Hei :-),
Nope, I think those are the only options:
   - save the output into a (real) file
   - keep using vsimem, but chain the operations while the app is still running
Do you have any particular reason to use vsimem?
Laurentiu
On Wed, Jan 17, 2024, at 14:00, nagyrobi_r at yahoo.com wrote:
Hei Laurențiu! Thank you for yor email!
Is there a way to pipe these operations or do anything fancy to be able to sit outside of a programming environment?
Cu respect,
Robert Nagy
On Wed, Jan 17, 2024 at 11:59 AM, Laurențiu Nicola via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240117/5c17eecf/attachment.htm>
