[gdal-dev] Where to fins my own files
Even Rouault even.rouault at spatialys.com
Wed Jan 17 08:12:41 PST 2024
Abel,
Le 17/01/2024 à 15:50, Abel Pau a écrit :
> Hi,
> ok Even,
> so, as my driver is not already online I have to do some changes at
> this part of the code, don’t I?
> At this moment I have the file in the folder GDAL\data (my GDAL_DATA
> environment variable).
> I call it like that.
> aMMIDDBFFile=CPLFindFile("gdal", "MM_m_idofic.csv");
> Do I have to move the file to somewhere? where?
I've merged the PR, so you can rebase on top of latest master
No change required in your .cpp file
The only change is to move the resource file into a data/ subdirectory
within your ogr/ogrsf_frmts/XXXX driver directory
and add in ogr/ogrsf_frmts/XXX/CMakeLists.txt
set(GDAL_DATA_FILES
     ${CMAKE_CURRENT_SOURCE_DIR}/data/MM_m_idofic.csv
set_property(
   TARGET ${GDAL_LIB_TARGET_NAME}
   APPEND
   PROPERTY RESOURCE "${GDAL_DATA_FILES}")
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240117/4a5ff787/attachment.htm>
