[gdal-dev] Where to fins my own files
Abel Pau a.pau at creaf.uab.cat
Thu Jan 18 12:12:46 PST 2024
Even,
thanks a lot.
I moved the file to {my GitHubDir}\GDAL\ogr\ogrsf_frmts\miramon\data\MM_m_idofic.csv
I changed my CMakeLists.txt  (see it below) as you indicated. And I deleted from gdal.cmake than now has only 5 files in there)
I rebased, deleted my gdal\build directory created the project again and built this.
An when I debug it seems that CPLFindFile("gdal", "MM_m_idofic.csv"); returns NULL. If I see inside it has only one locator and it seems that should be more, now...
I am missing something?
The CMakeLists
add_gdal_driver(
  TARGET ogr_MiraMon
  SOURCES ogrmiramondatasource.cpp ogrmiramondriver.cpp ogrmiramonlayer.cpp mm_wrlayr.c mm_gdal_functions.c mmrdlayr.c
  BUILTIN)
gdal_standard_includes(ogr_MiraMon)
target_include_directories(ogr_MiraMon PRIVATE $<TARGET_PROPERTY:ogrsf_generic,SOURCE_DIR>)
set(GDAL_DATA_FILES
    ${CMAKE_CURRENT_SOURCE_DIR}/data/MM_m_idofic.csv
set_property(
  TARGET ${GDAL_LIB_TARGET_NAME}
  APPEND
  PROPERTY RESOURCE "${GDAL_DATA_FILES}")
Thanks again
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: dimecres, 17 de gener de 2024 17:13
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Where to fins my own files
Abel,
Le 17/01/2024 à 15:50, Abel Pau a écrit :
ok Even,
so, as my driver is not already online I have to do some changes at this part of the code, don’t I?
At this moment I have the file in the folder GDAL\data (my GDAL_DATA environment variable).
I call it like that.
aMMIDDBFFile=CPLFindFile("gdal", "MM_m_idofic.csv");
Do I have to move the file to somewhere? where?
I've merged the PR, so you can rebase on top of latest master
No change required in your .cpp file
The only change is to move the resource file into a data/ subdirectory within your ogr/ogrsf_frmts/XXXX driver directory
and add in ogr/ogrsf_frmts/XXX/CMakeLists.txt
set(GDAL_DATA_FILES
set_property(
  APPEND
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240118/4eb31a01/attachment.htm>
