[gdal-dev] GPKG raster creation : error with too small resolution
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 18 05:42:35 PST 2024
Can you imagine using a custom tiling schema instead of the world-wide InspireCRS84Quad? These commands work
gdal_create -of GTiff -co COMPRESS=DEFLATE -outsize 2000 2000 -burn 255 -burn 0 -burn 0 -bands 3 -ot Byte -a_srs epsg:32631 -a_ullr 1000000 1000002 1000002 1000000 1mm.tif
gdal_translate -of GPKG  1mm.tif 1mm.gpkg
Notice the fixed ullr for making the image north-up.
-Jukka Rahkonen-
Input file size is 2000, 2000
0ERROR 6: Only north-up non rotated geotransform supported
..ERROR 1: Raster table 1mm not correctly initialized due to missing call to SetGeoTransform()
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Philippe Ghesquiere via gdal-dev
Lähetetty: torstai 18. tammikuuta 2024 15.22
Vastaanottaja: gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] GPKG raster creation : error with too small resolution
Dear all,
I just had an error while converting an image to GPKG. This image has a very small resolution and gdal_translate pops up an error message.
Test image :
gdal_create -of GTiff -co COMPRESS=DEFLATE -outsize 2000 2000 -burn 255 -burn 0 -burn 0 -bands 3 -ot Byte -a_srs epsg:32631 -a_ullr 1000000 1000000 1000002 1000002 1mm.tif
Conversion to GPKG :
gdal_translate -of GPKG -co TILING_SCHEME=InspireCRS84Quad -co ZOOM_LEVEL_STRATEGY=UPPER 1mm.tif 1mm.gpkg
ERROR 1: Could not find an appropriate zoom level
Analysis
The error is due to  ogrgeopackagedatasource.cpp<https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/gpkg/ogrgeopackagedatasource.cpp#L3169> (line 3169), and it does make sense : the zoom level is too high (Z>25).
However, wouldn't it be possible to modify gdal_translate behavior ?
For example, we could :
  *   let GDAL compute the appropriate zoom level : -co ZOOM_LEVEL_STRATEGY=AUTO/LOWER/UPPER,
  *   optionally specify a maximum zoom level : -co MAX_ZOOM_LEVEL=18
What do you think ?
Philippe
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240118/d40f53a7/attachment.htm>
