[gdal-dev] Fields of type List to simple fields with N times the feature?
Even Rouault even.rouault at spatialys.com
Fri Jan 19 08:15:41 PST 2024
Actually, an alternative would be that you type your list fields with
type=OFTString and subtype=OFSTJSon, and emit a serialized JSON array
(``[1,2]``). This is probably more in the spirit of nowadays uses, and
that should make all output drivers happy (at worse they won't
understand the JSON hint)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240119/ae2850e9/attachment.htm>
