[gdal-dev] Convert alpha to nodata?
Robert Coup robert.coup at koordinates.com
Fri Jan 19 08:40:28 PST 2024
Maybe it's just Friday, but I could use a pointer here :-)
My input raster is a RGBA byte image, where the alpha channel value is 0 or
255 (ie: effectively a mask). The output is ideally a VRT file, RGB with
Int16 data type, using nodata=-1.
So I want to convert the alpha channel to a nodata value.
The alpha/nodata/mask/band options to translate/warp haven't got me very
far, neither has hand-crafting various UseMaskBand/MaskBand elements in a
VRT.
I can do it to concrete tif files with something like this, repeating for
R,G,B and merge the output bands together, but it's a lot of processing.
  gdal_calc.py -A src.tif -B src.tif \
    --outfile out_b1.tif --co TILED=YES --type=Int16 --NoDataValue=-1 \
    --A_band=1 --B_band=4 --calc="where(B >= 128, A, -1)"
I feel like I'm probably missing a simpler path? (Which I will definitely
add to an Examples section somewhere)
Thanks,
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240119/94c1614b/attachment.htm>
