[gdal-dev] Inquiry about Elevation Values in DXF Conversion using ogr2ogr
Abel Pau a.pau at creaf.uab.cat
Wed Jan 24 07:15:53 PST 2024
HI,
I’ve checked that your file is correct but for some reason DXF does not get this capacity of variable elevation.
Sorry for not being more helpful.
Exporting with QGis also doesn’t work.
Perhaps is a matter of the format itself. Have you tried with other files and did it worked sometime?
De: Shahrukh Mirza Nawandish <mirza.nawandish at haritaevi.com>
Enviado el: dimecres, 24 de gener de 2024 15:19
Para: Abel Pau <a.pau at creaf.uab.cat>
CC: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Inquiry about Elevation Values in DXF Conversion using ogr2ogr
Thank you for your prompt response. I'm attaching the data file to this email for your convenience.
Appreciate your assistance.
24.01.2024, 17:02, "Abel Pau" <a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>>:
can you send us the file but not attached because it’s not allowed too much size in attachments.
Have you converted to another format to see if it’s a matter of KML or it’s general?
I’ll try to convert to MiraMon to test the elevations.
Thanks
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> En nombre de Shahrukh Mirza Nawandish via gdal-dev
Enviado el: dimecres, 24 de gener de 2024 14:13
Para: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Asunto: [gdal-dev] Inquiry about Elevation Values in DXF Conversion using ogr2ogr
Dear GDAL Team,
I hope this email finds you well. I'm encountering an issue when converting GeoJSON or KML files to DXF using ogr2ogr—specifically, the generated DXF file assigns a uniform elevation to all coordinates.
Your assistance in resolving this matter is highly appreciated.
Thank you,
Saygılarımla / Kind Regards
Shahrukh Mirza NAWANDISH
Havacılık Bilgi Sistemleri / Aeronautical Information Systems
Yazılım Geliştirme Uzm. Yrd. / Software Development Assist. Specialist
Bilgisayar Programcısı / Computer Programmer MCA
[https://www.haritaevi.com/wp-content/uploads/2023/10/Hevi100.png]<https://www.haritaevi.com/en/>
T:+90 312 266 66 98
M:+90 538 519 72 67
 E:mirza.nawandish at haritaevi.com<mailto:mirza.nawandish at haritaevi.com>
▶: Ankara-Istanbul-Bucharest<https://www.haritaevi.com/en/about-us/contact>
www.haritaevi.com<http://www.haritaevi.com/>
www.obstacleanalyze.com<http://www.obstacleanalyze.com/>
www.aixm.haritaevi.com<https://aixm.haritaevi.com/>
www.aerodatamarket.com<http://www.aerodatamarket.com/>
[https://avatars.mds.yandex.net/get-mail-signature/2434044/d24bf65965f2be07edc47ff3c25b0348/orig]<https://www.instagram.com/haritaevi/?hl=tr>[https://avatars.mds.yandex.net/get-mail-signature/200369/c75763261eac7fb671922d147573080b/orig]<https://www.linkedin.com/company/haritaevi-havac%C4%B1l%C4%B1k-m%C3%BChendislik-a-%C5%9F/>[https://avatars.mds.yandex.net/get-mail-signature/2434044/1cd6e615d44979bf9b0d6b0ea9c47182/orig]<https://twitter.com/haritaevi>[https://avatars.mds.yandex.net/get-mail-signature/232821/ec6941b191f27730d3a5f92fd846beb4/orig]<https://www.youtube.com/channel/UCZHA_PmyMLg__KOfNgOLJYg?view_as=subscriber>[https://avatars.mds.yandex.net/get-mail-signature/232821/0545b2da2dc9f49f532774615ec45e51/orig]<https://www.facebook.com/haritaevi/>[https://www.haritaevi.com/wp-content/uploads/2022/02/disclaimer_1.png]<https://www.haritaevi.com/disclaimer> [https://avatars.mds.yandex.net/get-mail-signature/2434044/58c47a3a908e28fdb209656734002f36/orig] <https://fidic.org/> [https://avatars.mds.yandex.net/get-mail-signature/2423644/1ccfc2184635533811e43aeeae4bf6c1/orig] <https://www.efcanet.org/> [https://avatars.mds.yandex.net/get-mail-signature/2423644/405b95fb41fb8db77dcee35ff542f333/orig] <https://www.haritaevi.com/en/about-us/quality-policy> [https://avatars.mds.yandex.net/get-mail-signature/1539903/c89e02562564f32028015473ea475742/orig] <https://www.haritaevi.com/en/about-us/information-security-policy>
Cumhuriyetimizin 100. Yılı Kutlu Olsun
Happy 100th Anniversary of Our Republic.
T:+90 312 266 66 98
M:+90 538 519 72 67
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240124/f7b4efce/attachment-0001.htm>
