[gdal-dev] Inquiry about Elevation Values in DXF Conversion using ogr2ogr
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jan 24 07:46:57 PST 2024
If I remember correctly, DXF does not support multipolygons with different
elevations.
On Wed, 24 Jan 2024 at 16:15, Abel Pau via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> HI,
> I’ve checked that your file is correct but for some reason DXF does not
> get this capacity of variable elevation.
> Sorry for not being more helpful.
> Exporting with QGis also doesn’t work.
> Perhaps is a matter of the format itself. Have you tried with other files
> and did it worked sometime?
> *De:* Shahrukh Mirza Nawandish <mirza.nawandish at haritaevi.com>
> *Enviado el:* dimecres, 24 de gener de 2024 15:19
> *Para:* Abel Pau <a.pau at creaf.uab.cat>
> *CC:* gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Inquiry about Elevation Values in DXF Conversion
> using ogr2ogr
> Hi,
> Thank you for your prompt response. I'm attaching the data file to this
> email for your convenience.
> Appreciate your assistance.
> 24.01.2024, 17:02, "Abel Pau" <a.pau at creaf.uab.cat>:
> Hi,
> can you send us the file but not attached because it’s not allowed too
> much size in attachments.
> Have you converted to another format to see if it’s a matter of KML or
> it’s general?
> I’ll try to convert to MiraMon to test the elevations.
> Thanks
> *De:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *En nombre de *Shahrukh
> Mirza Nawandish via gdal-dev
> *Enviado el:* dimecres, 24 de gener de 2024 14:13
> *Para:* gdal-dev at lists.osgeo.org
> *Asunto:* [gdal-dev] Inquiry about Elevation Values in DXF Conversion
> using ogr2ogr
> Dear GDAL Team,
> I hope this email finds you well. I'm encountering an issue when
> converting GeoJSON or KML files to DXF using ogr2ogr—specifically, the
> generated DXF file assigns a uniform elevation to all coordinates.
> Your assistance in resolving this matter is highly appreciated.
> Thank you,
> Saygılarımla / Kind Regards
> *Shahrukh Mirza NAWANDISH*
> Havacılık Bilgi Sistemleri / Aeronautical Information Systems
> Yazılım Geliştirme Uzm. Yrd. / Software Development Assist. Specialist
> Bilgisayar Programcısı / Computer Programmer MCA
> <https://www.haritaevi.com/en/>
> *T:*+90 312 266 66 98
> *M**:*+90 538 519 72 67
> * E:*mirza.nawandish at haritaevi.com
> *▶**:* Ankara-Istanbul-Bucharest
> <https://www.haritaevi.com/en/about-us/contact>
> *www.haritaevi.com <http://www.haritaevi.com/>*
> *www.obstacleanalyze.com <http://www.obstacleanalyze.com/>*
> *www.aixm.haritaevi.com <https://aixm.haritaevi.com/>*
> *www.aerodatamarket.com <http://www.aerodatamarket.com/>*
> <https://www.instagram.com/haritaevi/?hl=tr>
> <https://www.linkedin.com/company/haritaevi-havac%C4%B1l%C4%B1k-m%C3%BChendislik-a-%C5%9F/>
> <https://twitter.com/haritaevi>
> <https://www.youtube.com/channel/UCZHA_PmyMLg__KOfNgOLJYg?view_as=subscriber>
> <https://www.facebook.com/haritaevi/>
> <https://www.haritaevi.com/disclaimer>  <https://fidic.org/>
> <https://www.efcanet.org/>
> <https://www.haritaevi.com/en/about-us/quality-policy>
> <https://www.haritaevi.com/en/about-us/information-security-policy>
> Cumhuriyetimizin 100. Yılı Kutlu Olsun
> Happy 100th Anniversary of Our Republic.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240124/8498a9a4/attachment-0001.htm>
