[gdal-dev] Bad values when reading GCPs from a VRT file with gdalinfo in GDAL 3.8.3
Even Rouault even.rouault at spatialys.com
Thu Jan 25 04:21:48 PST 2024
will be fixed per https://github.com/OSGeo/gdal/pull/9136 . As a
workaround, you can spell them "inf" or "-inf" lowercase
Even
Le 25/01/2024 à 12:34, Pierluigi Guasqui via gdal-dev a écrit :
> Dear GDAL team,
> I am using GDAL version 3.8.3 and I am trying to extract GCPs values
> with gdalinfo tool from a VRT file (attached).
> As you can see by looking at the VRT file with a text editor GCP XYZ
> values are infinite values. When I read GCPs from the attached VRT
> file with gdalinfo (latest version GDAL v. 3.8.3) I am getting all zeros:
> GCP[  0]: Id=0, Info=
>           (0,0) -> (0,0,0)
> Instead, if I use gdalinfo (GDAL v. 3.6.3) I am getting the correct
> values:
>           (0,0) -> (inf,inf,-inf)
> Is this a bug with GDAL 3.8.3?
> Thank you for your help!
> Pierluigi Guasqui
> Software Engineer
> Applied Coherent Technology Corporation (ACT)
> www.actgate.com <http://www.actgate.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/ef3b293b/attachment-0001.htm>
