[gdal-dev] help
Marián Hadri Marian.Hadri at rib-software.com
Thu Jan 25 05:57:45 PST 2024
I'm trying to build the GDAL dll and lib files, so GDAL can be used for linker and includes in an other C++ project. We're needing to upgrade from GDAL 3.2.2 to 3.8.3. I try to create project file for VS 2019. In GDAL 3.2.2 was for that purpose used "generate_vcxproj.bat", which was in root directory. Now, this file is no there anymore. For that reason I try to do it with CMake program. But when I did it from cmd as " cmake -G "Visual Studio 16 2019" " or directly from Cmake, I got an error messages like this ...
CMake Error at C:/Program Files/CMake/share/cmake-3.28/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR) (Required is at least version "6.0")
Call Stack (most recent call first):
  C:/Program Files/CMake/share/cmake-3.28/Modules/FindPackageHandleStandardArgs.cmake:600 (_FPHSA_FAILURE_MESSAGE)
  cmake/modules/packages/FindPROJ.cmake:57 (find_package_handle_standard_args)
  cmake/helpers/CheckDependentLibraries.cmake:378 (find_package)
  gdal.cmake:265 (include)
  CMakeLists.txt:246 (include)
>From my point of view, it seems, that this is most important "Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR)
(Required is at least version "6.0")". Where and how I have to set that ? If I put that as Environment variables in CMake program like
PROJ_INCLUDE_DIR = -IC:\OSGeo4W\include
PROJ_LIBRARY = C:\OSGeo4W\lib
it did not work.
Marian Hadri
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/9512d179/attachment.htm>
