[gdal-dev] false easting and northing units
Even Rouault even.rouault at spatialys.com
Thu Jan 25 07:47:28 PST 2024
Kirk,
perhaps you could try using -a_srs EPSG:26988+6360 instead of a full
WKT. That way GDAL will *not* write the projected parameter definitions,
but just reference the horizontal and vertical CRS codes:
Geotiff_Information:
    Version: 1
    Key_Revision: 1.1
    Tagged_Information:
       ModelTiepointTag (2,3):
          0                 0                 0
          440720            3751320           0
       ModelPixelScaleTag (1,3):
          60                60                1
       End_Of_Tags.
    Keyed_Information:
       GTModelTypeGeoKey (Short,1): ModelTypeProjected
       GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
       GTCitationGeoKey (Ascii,46): "NAD83 / Michigan North + NAVD88
height (ftUS)"
       ProjectedCSTypeGeoKey (Short,1): PCS_NAD83_Michigan_North
       VerticalCSTypeGeoKey (Short,1): Code-6360 (NAVD88 height (ftUS))
       End_Of_Keys.
    End_Of_Geotiff.
Even
Le 25/01/2024 à 16:17, Even Rouault via gdal-dev a écrit :
> Kirk,
> this is a complicated story indeed... What changed since
> https://trac.osgeo.org/gdal/changeset/31405 is that OGC GeoTIFF 1.1
> was published, which mostly fixes issues with vertical CRS, which your
> CRS uses. So by default GDAL 3.1 or later, when seeing a CompoundCRS
> write it as GeoTIFF 1.1, and this new GeoTIFF version was the
> opportunity to remove writing the
> ProjLinearUnitsInterpCorrectGeoKey=3059 hack, since using GeoTIFF 1.1
> is a way to indicate that you're implementing correctly the standard.
> If you force writing GeoTIFF 1.0 by adding -co GEOTIFF_VERSION=1.0,
> GDAL will write the ProjLinearUnitsInterpCorrectGeoKey when needed,
> and listgeo will show the "Unknown-3059 (Short,1): Unknown-1" geotiff key.
> To know if a Geotiff is 1.0 or 1.1 with listgeo , look at the
> Key_Revision in the 3rd line which will be 1.0 or 1.1
> So I assume ArcPro doesn't specifically implement 1.1. Either they
> implement GeoTIFF themselves, or they use GDAL < 3.1 that hasn't
> GeoTIFF 1.1 explicit support
> Even
> Le 25/01/2024 à 15:24, Kirk Waters - NOAA Federal via gdal-dev a écrit :
>> Hi,
>> I've run across an odd issue with GeoTIFFS using custom projections
>> written by GDAL and their interpretation in ArcPro. The specific case
>> is doing a projection for Michigan State Plane North using
>> U.S. survey feet. [insert embarrassing tale of another US agency
>> wanting to always use survey feet regardless of state legislation or
>> that the federal government has been officially metric for a long
>> time]. For a file that should land in the Michigan upper peninsula,
>> ArcPro puts it in New Zealand. It appears the issue is that Arc is
>> interpreting the false easting as meters instead of survey feet. If I
>> do a define projection in ArcPro and make a custom projection, it
>> lands in the right place.
>> I used an old listgeo from the geotiff library to look at the tags
>> both in the original file and a copy that had define projection
>> applied to see what was different. They looked essentially the same,
>> including having the same value for the false easting. However, the
>> Arc version had an extra tag (3059) that wasn't in the GDAL produced
>> one. An internet search turned up this 13-year old GDAL issue
>> <https://trac.osgeo.org/gdal/ticket/3901>. If I understand it
>> correctly, a bug in GDAL was found that always used meters for the
>> false easting and northing. In addition to fixing that, a tag (3059)
>> was added to indicate this was fixed so software could differentiate
>> broken GDAL output from new output. It looks like Arc is looking for
>> this tag and if it's not there, false easting is assumed to be meters.
>> A few questions, assuming I interpreted that issue correctly:
>> 1) Why is gdal not adding that 3059 tag? (GDAL command used is below)
>> 2) If it's only supposed to be relevant to GDAL written files, why is
>> Arc writing it?
>> 3) How do I get GDAL to add the tag?
>> Command used in file creation:
>> gdal_translate -a_srs 'COMPD_CS[PROJCS["NAD83 / Michigan
>> North",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
>> 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",47.08333333333334],PARAMETER["standard_parallel_2",45.48333333333333],PARAMETER["latitude_of_origin",44.78333333333333],PARAMETER["central_meridian",-87],PARAMETER["false_easting",26246666.6666667],PARAMETER["false_northing",0],UNIT["US
>> survey
>> foot",0.304800609601219],AXIS["X",EAST],AXIS["Y",NORTH]],VERTCRS["NAVD88
>> height (ftUS)",  VDATUM["North American Vertical Datum 1988"],
>>  CS[vertical,1],  AXIS["gravity-related height (H)",up],
>>  LENGTHUNIT["US survey foot",0.304800609601], ID["EPSG",6360]]]' -co
>> TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=3 -co BIGTIFF=IF_SAFER
>> input.tif output.tif
>> Kirk Waters, PhD
>> NOAA Office for Coastal Management
>> Applied Sciences Program
>> coast.noaa.gov/digitalcoast <http://coast.noaa.gov/digitalcoast>
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240125/1c5ee8d8/attachment.htm>
