[gdal-dev] Virtual Raster Tile Index (VRTTI) driver, and associated gdaltindex improvements
Michael Sumner mdsumner at gmail.com
Tue Jan 30 03:31:01 PST 2024
awesome, thanks Even I'm having fun with this one.
For anyone interested I created Python to parse the OpenTopography COP90
VRT (I have to wget it locally as I don't know how to hit the URL for the
xml yet).
https://github.com/mdsumner/cog-example/blob/1ca74f3baffe69830180031ddabcbbc569816150/gti/cop90.py
(I'm using the DstRect to get efficient extent polygon of each tif without
opening them).
This writes a cop90.shp which can be GTI'd via
gdalinfo GTI:/vsicurl/
https://github.com/mdsumner/cog-example/raw/main/gti/cop90.shp
(seems I didn't get the SRS attached correctly).
I also have an R script in there for COP30 that I did previously to
FlatGeoBuf, I couldn't get FlatGeoBuf to work from Python and don't know
why.
If there's any pythonic-idiomatic advice on my code I'm very interested,
slowly I'll try to use this to do the same in C++.  If there's a faster way
to get these extents with GDAL I'm also keen to hear, thanks!
Cheers, Mike
On Fri, Jan 26, 2024 at 10:19 PM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> the driver has recently landed into GDAL master, renamed as GTI:
> https://gdal.org/drivers/raster/gti.html
> Can be tested using
> https://gdal.org/download.html#gdal-master-conda-builds , the refreshed
> ghcr.io/osgeo/gdal Docker image, or other nightly builds of GDAL master
> Even
> Le 20/12/2023 à 19:33, Even Rouault via gdal-dev a écrit :
> > Hi,
> > For those not actively following github tickets & PR, I just want to
> > point to a new pending major functionality to improve management of
> > virtual mosaics with a very large number of tiles/sources (> tens of
> > thousands of tiles), by referencing them as features of a vector layer
> > (typically created by gdaltindex), instead of a XML file as in
> > traditional VRT, augmented with additional metadata.
> > More details in https://github.com/OSGeo/gdal/pull/8983 (and in
> > initial ticket in https://github.com/OSGeo/gdal/issues/8861)
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Michael Sumner
Software and Database Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240130/13691a36/attachment.htm>
