[gdal-dev] Virtual Raster Tile Index (VRTTI) driver, and associated gdaltindex improvements
Even Rouault even.rouault at spatialys.com
Tue Jan 30 03:46:42 PST 2024
Michael,
You need to attach the CRS at layer creation time with:
layer = ds.CreateLayer(layer_name, geom_type=ogr.wkbPolygon, srs=sr)
Setting it with featureDefn.GetGeomFieldDefn(0).SetSpatialRef() is
illegal. Now that
https://gdal.org/development/rfc/rfc97_feature_and_fielddefn_sealing.html
has been implemented, you should have got an error... (assuming you run
your script with recent GDAL master)
from osgeo import ogr
ogr.UseExceptions()
ds = ogr.GetDriverByName('ESRI Shapefile').CreateDataSource('/tmp/foo.shp')
lyr = ds.CreateLayer('foo')
from osgeo import osr
sr = osr.SpatialReference()
sr.SetFromUserInput("OGC:CRS84")
featureDefn = lyr.GetLayerDefn()
featureDefn.GetGeomFieldDefn(0).SetSpatialRef(sr)
   File "<stdin>", line 1, in <module>
   File "/home/even/gdal/gdal/build_cmake/swig/python/osgeo/ogr.py",
line 6017, in SetSpatialRef
     return _ogr.GeomFieldDefn_SetSpatialRef(self, *args)
RuntimeError: OGRGeomFieldDefn::SetSpatialRef() not allowed on a sealed
object
I can't think of a reason why your script wouldn't work with a
FlatGeoBuf output (did you get an error message?), which would be much
better, as you could also attach the XRES, YRES, BANDCOUNT, etc.
metadata items that would help the GTI driver avoid probing one of the
tiles.
Even
Le 30/01/2024 à 12:31, Michael Sumner a écrit :
> awesome, thanks Even I'm having fun with this one.
> For anyone interested I created Python to parse the OpenTopography
> COP90 VRT (I have to wget it locally as I don't know how to hit the
> URL for the xml yet).
> https://github.com/mdsumner/cog-example/blob/1ca74f3baffe69830180031ddabcbbc569816150/gti/cop90.py
> (I'm using the DstRect to get efficient extent polygon of each tif
> without opening them).
> This writes a cop90.shp which can be GTI'd via
> gdalinfo
> GTI:/vsicurl/https://github.com/mdsumner/cog-example/raw/main/gti/cop90.shp
> (seems I didn't get the SRS attached correctly).
> I also have an R script in there for COP30 that I did previously to
> FlatGeoBuf, I couldn't get FlatGeoBuf to work from Python and don't
> know why.
> If there's any pythonic-idiomatic advice on my code I'm very
> interested, slowly I'll try to use this to do the same in C++.  If
> there's a faster way to get these extents with GDAL I'm also keen to
> hear, thanks!
> Cheers, Mike
> On Fri, Jan 26, 2024 at 10:19 PM Even Rouault via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
>     Hi,
>     the driver has recently landed into GDAL master, renamed as GTI:
>     https://gdal.org/drivers/raster/gti.html
>     Can be tested using
>     https://gdal.org/download.html#gdal-master-conda-builds , the
>     refreshed
>     ghcr.io/osgeo/gdal <http://ghcr.io/osgeo/gdal> Docker image, or
>     other nightly builds of GDAL master
>     Even
>     Le 20/12/2023 à 19:33, Even Rouault via gdal-dev a écrit :
>     > Hi,
>     > For those not actively following github tickets & PR, I just
>     want to
>     > point to a new pending major functionality to improve management of
>     > virtual mosaics with a very large number of tiles/sources (>
>     tens of
>     > thousands of tiles), by referencing them as features of a vector
>     layer
>     > (typically created by gdaltindex), instead of a XML file as in
>     > traditional VRT, augmented with additional metadata.
>     > More details in https://github.com/OSGeo/gdal/pull/8983 (and in
>     > initial ticket in https://github.com/OSGeo/gdal/issues/8861)
>     > Even
>     http://www.spatialys.com
>     My software is free, but my time generally not.
>     _______________________________________________
>     gdal-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240130/2b0e010e/attachment-0001.htm>
