[gdal-dev] Virtual Raster Tile Index (VRTTI) driver, and associated gdaltindex improvements
Michael Sumner mdsumner at gmail.com
Tue Jan 30 03:54:36 PST 2024
ah thanks, all very helpful - no it's not done with master (for various
reasons), I'll follow up with details if relevant, mostly I was just
excited to get a useable workflow for the entire process.
Cheers, Mike
On Tue, 30 Jan 2024, 22:46 Even Rouault, <even.rouault at spatialys.com> wrote:
> Michael,
> You need to attach the CRS at layer creation time with:
> layer = ds.CreateLayer(layer_name, geom_type=ogr.wkbPolygon, srs=sr)
> Setting it with featureDefn.GetGeomFieldDefn(0).SetSpatialRef() is
> illegal. Now that
> https://gdal.org/development/rfc/rfc97_feature_and_fielddefn_sealing.html
> has been implemented, you should have got an error... (assuming you run
> your script with recent GDAL master)
> from osgeo import ogr
> ogr.UseExceptions()
> ds = ogr.GetDriverByName('ESRI Shapefile').CreateDataSource('/tmp/foo.shp')
> lyr = ds.CreateLayer('foo')
> from osgeo import osr
> sr = osr.SpatialReference()
> sr.SetFromUserInput("OGC:CRS84")
> featureDefn = lyr.GetLayerDefn()
> featureDefn.GetGeomFieldDefn(0).SetSpatialRef(sr)
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File "/home/even/gdal/gdal/build_cmake/swig/python/osgeo/ogr.py", line
> 6017, in SetSpatialRef
>     return _ogr.GeomFieldDefn_SetSpatialRef(self, *args)
> RuntimeError: OGRGeomFieldDefn::SetSpatialRef() not allowed on a sealed
> object
> I can't think of a reason why your script wouldn't work with a FlatGeoBuf
> output (did you get an error message?), which would be much better, as you
> could also attach the XRES, YRES, BANDCOUNT, etc. metadata items that would
> help the GTI driver avoid probing one of the tiles.
> Even
> Le 30/01/2024 à 12:31, Michael Sumner a écrit :
> awesome, thanks Even I'm having fun with this one.
> For anyone interested I created Python to parse the OpenTopography COP90
> VRT (I have to wget it locally as I don't know how to hit the URL for the
> xml yet).
> https://github.com/mdsumner/cog-example/blob/1ca74f3baffe69830180031ddabcbbc569816150/gti/cop90.py
> (I'm using the DstRect to get efficient extent polygon of each tif without
> opening them).
> This writes a cop90.shp which can be GTI'd via
> gdalinfo GTI:/vsicurl/
> https://github.com/mdsumner/cog-example/raw/main/gti/cop90.shp
> (seems I didn't get the SRS attached correctly).
> I also have an R script in there for COP30 that I did previously to
> FlatGeoBuf, I couldn't get FlatGeoBuf to work from Python and don't know
> why.
> If there's any pythonic-idiomatic advice on my code I'm very interested,
> slowly I'll try to use this to do the same in C++.  If there's a faster way
> to get these extents with GDAL I'm also keen to hear, thanks!
> Cheers, Mike
> On Fri, Jan 26, 2024 at 10:19 PM Even Rouault via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hi,
>> the driver has recently landed into GDAL master, renamed as GTI:
>> https://gdal.org/drivers/raster/gti.html
>> Can be tested using
>> https://gdal.org/download.html#gdal-master-conda-builds , the refreshed
>> ghcr.io/osgeo/gdal Docker image, or other nightly builds of GDAL master
>> Even
>> Le 20/12/2023 à 19:33, Even Rouault via gdal-dev a écrit :
>> > Hi,
>> > For those not actively following github tickets & PR, I just want to
>> > point to a new pending major functionality to improve management of
>> > virtual mosaics with a very large number of tiles/sources (> tens of
>> > thousands of tiles), by referencing them as features of a vector layer
>> > (typically created by gdaltindex), instead of a XML file as in
>> > traditional VRT, augmented with additional metadata.
>> > More details in https://github.com/OSGeo/gdal/pull/8983 (and in
>> > initial ticket in https://github.com/OSGeo/gdal/issues/8861)
>> > Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> -- http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240130/fa96e778/attachment.htm>
