[gdal-dev] Is there any RHEL repo for relatively new GDAL versions?
Even Rouault even.rouault at spatialys.com
Tue Jan 30 07:50:07 PST 2024
Hi Jukka,
this is a unfortunate move. You may have to create a custom package,
possibly inspired from src.rpm from recent Fedora
(https://src.fedoraproject.org/rpms/gdal). I see Markus Neteler did one
for GDAL 3.0.4 for RHEL 7 in
https://copr.fedorainfracloud.org/coprs/neteler/GDAL/
Or I assume that you may install it also from conda-forge. I believe
their Linux binaries should run on RHEL 8.
Actually, quickly checking with AlmaLinux 8, a free clone of RHEL 8:
# docker run --rm -it almalinux:8
# dnf install wget
# wget https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-x86_64.sh
# sh Miniconda3-latest-Linux-x86_64.sh   # answer to default questions
with [Enter]
# source /root/miniconda3/bin/activate
# conda install -c conda-forge gdal
# gdalinfo --version
GDAL 3.8.3, released 2024/01/04
Or if you only use command line utilities, use Docker images
PS: IT policies are weird. It is paradoxical to trust more an outside
source for binaries rather than building your own from source...
Even
Le 30/01/2024 à 16:09, Rahkonen Jukka via gdal-dev a écrit :
> Hi,
> The newest GDAL in the official RHEL repo is 3.4.3, released
> 2022-04-22. There used to be GDAL 3.7 available from the PostgreSQL
> repo https://yum.postgresql.org/repopackages/ and we have been using
> that, but the version was removed recently. Some other user was
> unhappy as well and created a bug
> Bug #7943: Providers missing from pgdg-common for GDAL 3.7
> (RHEL/CentOS/AlmaLinux 8) - PostgreSQL YUM Repository - Redmine -
> PostgreSQL community <https://redmine.postgresql.org/issues/7943>
> That user got this feedback:
> “Why did you install GDAL 3.7? The packages are in the repo, but they
> were never required by any released GIS suite. I even removed them
> from git a couple of weeks ago:
> https://git.postgresql.org/gitweb/?p=pgrpms.git;a=commitdiff;h=059f17f664ab093af35389dc7ec7b62c5a9f3fe2
> <https://git.postgresql.org/gitweb/?p=pgrpms.git;a=commitdiff;h=059f17f664ab093af35389dc7ec7b62c5a9f3fe2>
> Commit comment: gdal35 and gdal37: Remove from the repo. Not used in
> any packages.
> By our agency’s IT policy compiling GDAL by ourselves is not possible.
> Can anyone suggest other acceptable means for getting at least GDAL
> 3.7 for RHEL 8?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240130/4fc93453/attachment.htm>
