[gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
Even Rouault even.rouault at spatialys.com
Fri Mar 1 02:43:21 PST 2024
this looks like potentially some memory usage issue that popups
"randomly" on some platforms. The fact that you reproduce it on your
22.04 build is encouraging since it will make it easier to debug
try the following:
sudo apt-get install gdb valgrind
gdb --args test_ogrsf -all_drivers
run
and hopefully it will crash and give you some hints
and/or
valgrind test_ogrsf -all_drivers
Even
Le 01/03/2024 à 11:29, Abel Pau via gdal-dev a écrit :
> Hi,
> yesterday I updated my personal branch (soon I’ll do a pull request)
> but before as Even suggested I’m trying to make green al Actions.
> The only problem I have now is at some points on tests...
> But I am missing something because I there are things I don’t
> understand well.
> Can anyone give me some new information to clarify myself?
> *test_ogr_basic_10*
> It’s this INFO message (that other drivers also give) a problem?
> INFO: MiraMonVector: Creation of /foo\test.pol should have failed.
> This message also appears in some other drivers.
> INFO: MiraMonVector: CreateFeature() at line 780 succeeded but failed
> to assign FID to feature.
> Al tests in Linux Builds
> <https://github.com/AbelPau/gdal/actions/runs/8101809119> (in Actions)
> are OK except *Alpine, gcc 32-bit*
> MiraMonVector driver (the one I am testing) seems to be OK.
> gcore/test_driver_metadata.py::test_metadata_dcap_yes[MiraMonVector]
> PASSED [ 38%]
> gcore/test_driver_metadata.py::test_metadata_openoptionlist[MiraMonVector]
> PASSED [ 40%]
> gcore/test_driver_metadata.py::test_metadata_creationoptionslist[MiraMonVector]
> PASSED [ 42%]
> gcore/test_driver_metadata.py::test_metadata_layer_creationoptionslist[MiraMonVector]
> PASSED [ 42%]
> gcore/test_driver_metadata.py::test_metadata_creation_field_datatypes[MiraMonVector]
> PASSED [ 44%]
> gcore/test_driver_metadata.py::test_metadata_creation_sub_field_datatypes[MiraMonVector]
> PASSED [ 46%]
> gcore/test_driver_metadata.py::test_metadata_alter_geom_field_defn_flags[MiraMonVector]
> PASSED [ 47%]
> gcore/test_driver_metadata.py::test_metadata_alter_field_defn_flags[MiraMonVector]
> PASSED [ 48%]
> gcore/test_driver_metadata.py::test_metadata_creation_field_defn_flags[MiraMonVector]
> PASSED [ 48%]
> But
> 2024-02-29T20:01:51.4283306Z ogr/ogr_basic_test.py::test_ogr_basic_10
> FAILED                    [  1%]
> =================================== FAILURES
> ______________________________ test_ogr_basic_10
> _______________________________
> Al some point: ERROR ret code = -6
> *But no more clues why.*
> Anyone can tell me how to explore this error?
> I debugged this test in windows but all seems correct.
> The program '[15680] test_ogrsf.exe' has exited with code 0 (0x0).
> I finally installed a linux ubuntu:22.04  in a docker and I can do
> some things related to tests.
> When I do
> python3 -m pytest -vv -p no:sugar --color=no
> After a while this error appears.
> So, why?
> E         INFO: OpenFileGDB: CreateFeature() at line 837 failed but
> without explicit error.
> E         INFO: TestCreate(DXF).
> E         INFO: DXF: Creation of /foo/test.
> *E         ERROR ret code = -9*
> E       assert 'ERROR' not in 'INFO: TestCreate(PCIDSK).\nINFO:
> PCIDSK: Creation of /foo/test.pix should have failed.\nINFO:
> TestCreate(netCDF).\nINFO: netCDF: Creation of /foo/test.nc should
> have failed.\nINFO: netCDF: Creation of /vsimem/test33.n....
> *Abel Pau Garcia*
> *GIS developer*
> https://www.creaf.cat/sites/default/files/creaf-signature.png
> *a.pau at creaf.uab.cat* <mailto:a.pau at creaf.uab.cat>
> *Let's chat on Teams!*
> <https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
> *Tel. +34 934814277*
> https://www.creaf.cat/sites/default/files/so-en-signature.png
> https://www.creaf.cat/sites/default/files/twitter-icon-signature.png
> <https://twitter.com/CREAF_ecologia>https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png
> <https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>https://www.creaf.cat/sites/default/files/youtube-icon-signature.png
> <https://www.youtube.com/c/creafecologia>https://www.creaf.cat/sites/default/files/instagram-icon-signature.png
> <https://www.instagram.com/CREAF_ecologia/>
> *www.creaf.cat* <http://www.creaf.cat>*| **http://blog.creaf.cat*
> <http://blog.creaf.cat>
> https://www.creaf.cat/sites/default/files/uab_logo_signatura.png
> CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
> Before printing this electronic message, think about the environment.
> http://www.creaf.uab.cat/_signatura/line.gif
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0011.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/31190779/attachment-0003.jpg>
