[gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
Abel Pau a.pau at creaf.uab.cat
Fri Mar 1 03:59:32 PST 2024
Hi, and thanks for the answer.
Valgrint give me that info
INFO: TestCreate(JSONFG).
INFO: JSONFG: Creation of /foo/test.json should have failed.
INFO: JSONFG: CreateFeature() at line 780 succeeded but failed to assign FID to feature.
INFO: TestCreate(MiraMonVector).
INFO: MiraMonVector: Creation of /foo/test.pol should have failed.
INFO: MiraMonVector: CreateFeature() at line 780 succeeded but failed to assign FID to feature.
Killed
If I add –v to valgrint, same thing. Nothing more concrete
Same for gdb.
I’ll try some prints (or the log system) to see where exactly it crashes.
De: Even Rouault <even.rouault at spatialys.com>
Enviado el: divendres, 1 de març de 2024 11:43
Para: Abel Pau <a.pau at creaf.uab.cat>; gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
this looks like potentially some memory usage issue that popups "randomly" on some platforms. The fact that you reproduce it on your 22.04 build is encouraging since it will make it easier to debug
try the following:
sudo apt-get install gdb valgrind
gdb --args test_ogrsf -all_drivers
run
and hopefully it will crash and give you some hints
and/or
valgrind test_ogrsf -all_drivers
Even
Le 01/03/2024 à 11:29, Abel Pau via gdal-dev a écrit :
yesterday I updated my personal branch (soon I’ll do a pull request) but before as Even suggested I’m trying to make green al Actions.
The only problem I have now is at some points on tests...
But I am missing something because I there are things I don’t understand well.
Can anyone give me some new information to clarify myself?
test_ogr_basic_10
It’s this INFO message (that other drivers also give) a problem?
INFO: MiraMonVector: Creation of /foo\test.pol should have failed.
This message also appears in some other drivers.
Al tests in Linux Builds<https://github.com/AbelPau/gdal/actions/runs/8101809119> (in Actions) are OK except Alpine, gcc 32-bit
MiraMonVector driver (the one I am testing) seems to be OK.
gcore/test_driver_metadata.py::test_metadata_dcap_yes[MiraMonVector] PASSED [ 38%]
gcore/test_driver_metadata.py::test_metadata_openoptionlist[MiraMonVector] PASSED [ 40%]
gcore/test_driver_metadata.py::test_metadata_creationoptionslist[MiraMonVector] PASSED [ 42%]
gcore/test_driver_metadata.py::test_metadata_layer_creationoptionslist[MiraMonVector] PASSED [ 42%]
gcore/test_driver_metadata.py::test_metadata_creation_field_datatypes[MiraMonVector] PASSED [ 44%]
gcore/test_driver_metadata.py::test_metadata_creation_sub_field_datatypes[MiraMonVector] PASSED [ 46%]
gcore/test_driver_metadata.py::test_metadata_alter_geom_field_defn_flags[MiraMonVector] PASSED [ 47%]
gcore/test_driver_metadata.py::test_metadata_alter_field_defn_flags[MiraMonVector] PASSED [ 48%]
gcore/test_driver_metadata.py::test_metadata_creation_field_defn_flags[MiraMonVector] PASSED [ 48%]
But
2024-02-29T20:01:51.4283306Z ogr/ogr_basic_test.py::test_ogr_basic_10 FAILED                          [  1%]
=================================== FAILURES ===================================
______________________________ test_ogr_basic_10 _______________________________
Al some point: ERROR ret code = -6
But no more clues why.
Anyone can tell me how to explore this error?
I debugged this test in windows but all seems correct.
The program '[15680] test_ogrsf.exe' has exited with code 0 (0x0).
I finally installed a linux ubuntu:22.04  in a docker and I can do some things related to tests.
When I do
python3 -m pytest -vv -p no:sugar --color=no ogr/ogr_basic_test.py::test_ogr_basic_10
After a while this error appears.
So, why?
E         INFO: OpenFileGDB: CreateFeature() at line 837 failed but without explicit error.
E         INFO: TestCreate(DXF).
E         INFO: DXF: Creation of /foo/test.
E         ERROR ret code = -9
E       assert 'ERROR' not in 'INFO: TestCreate(PCIDSK).\nINFO: PCIDSK: Creation of /foo/test.pix should have failed.\nINFO: TestCreate(netCDF).\nINFO: netCDF: Creation of /foo/test.nc should have failed.\nINFO: netCDF: Creation of /vsimem/test33.n....
Abel Pau Garcia
GIS developer
[https://www.creaf.cat/sites/default/files/creaf-signature.png]
a.pau at creaf.uab.cat<mailto:a.pau at creaf.uab.cat>
Let's chat on Teams!<https://teams.microsoft.com/l/chat/0/0?users=a.pau@creaf.uab.cat>
Tel. +34 934814277
[https://www.creaf.cat/sites/default/files/so-en-signature.png]
[https://www.creaf.cat/sites/default/files/twitter-icon-signature.png]<https://twitter.com/CREAF_ecologia>[https://www.creaf.cat/sites/default/files/linkedin-icon-signature.png]<https://www.linkedin.com/company/1363052?trk=tyah&trkInfo=clickedVertical:company,clickedEntityId:1363052,idx:2-1-2,tarId:1465807877789,tas:creaf>[https://www.creaf.cat/sites/default/files/youtube-icon-signature.png]<https://www.youtube.com/c/creafecologia>[https://www.creaf.cat/sites/default/files/instagram-icon-signature.png]<https://www.instagram.com/CREAF_ecologia/>
www.creaf.cat<http://www.creaf.cat> | http://blog.creaf.cat
[https://www.creaf.cat/sites/default/files/uab_logo_signatura.png]
CREAF. Campus UAB. Edifici C. 08193 Bellaterra (Barcelona)
Before printing this electronic message, think about the environment.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0006.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0007.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0008.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0009.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0010.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0011.png>
Type: image/jpeg
Desc: image007.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0002.jpg>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240301/33176d70/attachment-0003.jpg>
